Glove Test - Wrist Twisters
post #1 of 19 Old 09-25-2006, 10:07 AM Thread Starter
Two Wheeled Warlord
Danke's Avatar
Glove Test
Of course mostly brands or platforms for Europe only but still a few familar faces.
Ride Test
Danke is offline
post #2 of 19 Old 09-25-2006, 10:13 AM
did you notice that the top rated glove had a visor squeegee?
post #3 of 19 Old 09-25-2006, 10:16 AM
The "Eagle" Has Landed
Aquila-RC51's Avatar
Bite Me!
Aquila-RC51 is offline
post #4 of 19 Old 09-25-2006, 10:18 AM
I thought that might pull you out of the shadows.
post #5 of 19 Old 09-25-2006, 10:24 AM
Ride Test
I like this. Where can I get more of this? Is that an Organization that does regular testing of products?
Jet - Maybe you can utilize some of their ideas for the tests you want to do?
post #6 of 19 Old 09-25-2006, 10:25 AM
I am reposting to keep bumping this thread. The information is very valuable.
Ridge... weren't you supposed to be giving up some color ideas? Huh? Huh?
post #7 of 19 Old 09-25-2006, 10:27 AM
<------------ See Avatar for my current disposition as to the juggling of stressors right now. I'm woking on it, don't you fret your little head.
post #8 of 19 Old 09-25-2006, 10:41 AM
Believe it or not, I understand how you must feel... this is one of those Mondays I wish I called in sick!
NOW GET TO WORK ON IT!
post #9 of 19 Old 09-25-2006, 11:19 AM
Wookie
ragdoll's Avatar
Seems a little odd, the way they rank gloves.
The further down the list you go, the higher the score. But use the Joe Rocket SpeedMaster gloves for an example of odd ranking. It has a high score but the palm strength is only 2\10? Durrr.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #10 of 19 Old 09-25-2006, 11:22 AM
That is actually what makes this interesting. The winner shows overall quality in ALL areas. That means they do not assume that accidents will happen one way, and they also don't skimp on their gloves regardless of the sections. Remember, leather gear is made up of panels, you can compromise safety by compromizing quality elsewhere.
This report allows you to read between the lines. Where one might have Un-Obtanium material on the Knuckles does not mean it is the same in the entire glove.
To be fair to JR, I decided to go check out the glove that was tested. Firstly, most of the shots of these gloves are always shot from the top... rarely the bottom or palm area. Then I started to assess the design. Now, this is just my opinion and strictly mine alone:
The palm seems a bit busy with a lot of the stitching exposed. Considering JR products are often criticized for weak joint, I would imagine that those stitches in the palm failed. Again, when you look closely at the data and the test parameters, the JR scored low on the seam strength. There is also little to no padding for the palm area, that means on impact, not only would you feel the impact, there is little to act as a cushion between your hands pressure to the tarmac and the material left to protect you..... I would imagine higher friction rates would occur, again leading to earlier failure of that are. JR claims to use Pittards&#174; Ceramic infused leather Armor Tan™ palm - I have no idea what that means. But... if I were to infer what from what I know about SIDI boots and their ceramic toe sliders, it would mean rougher edge, again again, increased friction.
Here is a pic:
post #11 of 19 Old 09-25-2006, 01:02 PM
Wookie
ragdoll's Avatar
You said assess... huh huh huh
'02 RC-51
'10 Unicycle
ragdoll is offline
post #12 of 19 Old 09-26-2006, 02:15 PM
Okay young man... don't get all excited yet, RC90 is yet to make an appearance to "assess" this issue.....
Seriously though, did that make sense to ya?
post #13 of 19 Old 09-26-2006, 03:12 PM
Wookie
ragdoll's Avatar
Ja
'02 RC-51
'10 Unicycle
ragdoll is offline
post #14 of 19 Old 09-26-2006, 03:43 PM
Ja
Zie sprechen sie Duetsch? Gut!
post #15 of 19 Old 09-26-2006, 04:48 PM
Wookie
ragdoll's Avatar
Ich spreche nur ein klein wenig Deutsch. Nicht so gut. Ich erlerne.
Um... Adolf Hitler saugt!
'02 RC-51
'10 Unicycle
ragdoll is offline
post #16 of 19 Old 09-26-2006, 05:38 PM
Suben strugen bajen... no?
RC90 is offline
post #17 of 19 Old 09-26-2006, 06:01 PM
Wookie
ragdoll's Avatar
Ummm... what? You Swiss?
'02 RC-51
'10 Unicycle
ragdoll is offline
post #18 of 19 Old 09-27-2006, 10:18 PM
Wim, RIDE is a UK rag you can buy at Barnes&Noble. I like their tests, they usually do big exhaust tests which no one over here seems to do.
I have the Held Krypton gloves and I like em.
RayRevolver is offline
post #19 of 19 Old 09-28-2006, 08:42 AM
Thanks Ray - least we know you is not Swiss
