Very old nooby! - Wrist Twisters
post #1 of 17 Old 03-19-2015, 11:57 AM Thread Starter
Very old nooby!
Hi all, I'm Chris. On the cusp of 75 and still enjoying my motorcycling.
We have three bikes at the moment, the indomitable Yam XS850 Triple, the sleek and reliable Deauville and the beemer F650 GS.
Still finding our way round the Honda and the BMW.
I've got the Haynes for the Deauville but it doesn't show how to get the rear brake lever off!
It's things like that I hope to learn from this site.
Good riding, spring's nearly here :-)
Regards
Chris
Crb999 is offline
post #2 of 17 Old 03-19-2015, 12:01 PM
Howdy and welcome
post #3 of 17 Old 03-19-2015, 12:36 PM
Welcome to the forums. Definitely, a wealth of knowledge here.
post #4 of 17 Old 03-19-2015, 12:36 PM
Regards
Chris
Haynes used to be a solid choice, but since about 1980 it's become more and more useless. These days the only thing their product is good for is jackstand padding or birdcage liner. With the advent of the internet as a popular tool, people often go looking for PDF copies of the factory service manual.
What year's the Deauville?
CB700S is online now
post #5 of 17 Old 03-19-2015, 12:56 PM Thread Starter
Hi CB700S,
It is 2002 V2
I unscrewed the large hex bolt that goes through the pannier attachment and rather expected the brake pedal to loosen up if that bolt was also the axle. But it clearly isn't.
How much do I have to take off to be able to grease up the pivot?
Regards
Chris
Crb999 is offline
post #6 of 17 Old 03-19-2015, 02:23 PM
Philanthropist
Dave W.'s Avatar
Hello and welcome.
Dave W. is offline
post #7 of 17 Old 03-19-2015, 02:38 PM
Welcome Chris! Great to have you here.
post #8 of 17 Old 03-19-2015, 03:01 PM
Welcome to the nuthouse, enjoy your stay. Please don't feed the waffles.
post #9 of 17 Old 03-19-2015, 03:15 PM
Welcome to the nuthouse, enjoy your stay. Please don't stomp the waffles.
FTFY.
Welcome!!!
post #10 of 17 Old 03-19-2015, 03:52 PM
Hi CB700S,
It is 2002 V2
Regards
Chris
So what you're trying to do is remove the brake pedal from the pivot to grease it?
FYI, you can get the actual Honda service manual, in English, via Torrent from here: http://www.torrentino.ru/torrents/18...orkshop-manual
Just press the green Russian Download button and use whatever torrent client you wish to download it utilizing the resulting file.
Looks like it comes off just like the 919 does - remove the cotter pin, push out the odd clevis pin to disconnect the brake pedal arm from the master cylinder (look out for master cylinder leaks!) Once that's done, remove the C-clip and washer holding the pedal onto the pivot and then remove the pedal. No bolt removal required - make sure you put back whatever bolt it was you removed and torque it to spec.
post #11 of 17 Old 03-19-2015, 03:54 PM
Is there a wrist pin at the back of the pivot bolt? Or a circlip?
post #12 of 17 Old 03-19-2015, 03:55 PM
post #13 of 17 Old 03-19-2015, 04:01 PM
It's the same C-clip or circlip the 919 has. No, literally, same one.
This is how easy the brake pedal comes off after you've disconnected it from the master cylinder and removed the C-clip/circlip that holds it onto the pivot. Or the C-clip and washer have disappeared - which is what happened to me.
post #14 of 17 Old 03-19-2015, 07:16 PM
Hello and welcome!
post #15 of 17 Old 03-19-2015, 07:31 PM
TEXAN
MF1VE's Avatar
+1 hello and welcome to WT.
MF1VE is offline
post #16 of 17 Old 03-19-2015, 07:47 PM
Welcome! Enjoy your stay, we have characters of all sorts with the same common interest.
post #17 of 17 Old 03-19-2015, 09:50 PM
NWTB Non Stinky 919
jeffie7's Avatar
Howdy, and welcome!
jeffie7 is offline
