So who's 919 did I just buy? - Wrist Twisters
 1Likes
  • 1 Post By Mike Kline
post #1 of 5 Old 11-14-2020, 10:48 AM Thread Starter
Shootist357
Mike Kline's Avatar
Greetings! I just picked up this 919 in the FL panhandle and based on what I see, it probably belonged to a wrist twister guy!
2004 919 in factory green with a two brothers exhaust, K&N filter, pro taper bars, steel slider pegs, blocking plates installed, and who knows what else.... factory rear shock appears shot--bottoms out effortlessly (any ideas? can't afford much for parts)... smokes a little, so I drained the tank and refilled with fresh gas and some seafoam. Probably just go ahead and order a new FPR (34k on odometer).
I'm a bike lover at heart-- have a few KLR650's, an ST1300, and a little suzuki DR200 trail bike. This will be a good one to clean up and make a daily rider. Already ordered a mini windscreen for it.
Mike
Dario_hawk likes this.
Mike Kline is offline
post #2 of 5 Old 11-15-2020, 12:13 AM
Wanna free cat?
rufftup's Avatar
Welcome to the forum and congrats on the bike.. IMO- If you're going to spend money on mods, go with some braided brake lines. You will be impressed. If you need a new rear rotor, hmu. I have an OEM that is yours for shipping from 75701
--- Mae West
2007 CB900F
rufftup is offline
post #3 of 5 Old 11-15-2020, 03:48 PM Thread Starter
Shootist357
Mike Kline's Avatar
Most of my bikes get braided lines, even the KLR's! Biggest concern right now is the rear shock issue--I'll play with it this week. I'm 180 lbs and even on the lowest setting I can't get the sag to 1" (measuring slightly behind rear peg area).
Buy a helmet that costs as much as you think your head is worth...
post #4 of 5 Old 11-15-2020, 04:18 PM
There is a guy in Northern Indiana that will rebuild that shock. I think he goes by DMr. Your forks probably need some help also. Do brake lines, they're not hard.
Sniper-x is offline
post #5 of 5 Old 11-16-2020, 02:53 PM
Sag is vertical measure as referenced to axle centreline.
So you are getting incorrect low values.
Your true sag will be a simple factor of L2/L1 X your present measurement.
L1 being your reference point to swing arm pivot pin centreline.
L2 being axle centreline to swing arm pivot pin centreline.
I'd expect a decent axle referenced sag number at shock position 1 with the early spring.
mcromo44 is online now
