New member and a cbr900rr owner - Wrist Twisters
 1Likes
  • 1 Post By martin_deyanov
post #1 of 10 Old 02-10-2017, 05:24 PM Thread Starter
Hey guys,
New member here.
I ride a 97 900RR blade, modified over the years:
- Streetfightered - stripped all front fairings, headlight and dash, just a ricambi weiss bellypan
- Complete 954 front end - triples, forks, brakes, clip-ons
- 954 front and rear wheels
I have been tracking the hell out of it last year and quickly realized suspension needs a bit of work and also stock footpegs sit really low... having scraped almost half an inch off each of them
Anyways, currently in the process of respringing the forks to my weight, reshiming the stock compression valves (actually found the forum looking for info on that), replacing the rear shock with a mint 954 one and looking for rear sets options.
Love the forums, a good deal of information here.
File Type: jpg 10404002_10206557280304142_5465189198071639532_o.jpg (121.4 KB, 22 views)
File Type: jpg 12109910_10206557278384094_6029208459887580304_o.jpg (164.4 KB, 23 views)
LDH likes this.
martin_deyanov is offline
post #2 of 10 Old 02-10-2017, 07:21 PM
Originally Posted by martin_deyanov View Post
Hey guys,
New member here.
Nice!
And welcome aboard.
post #3 of 10 Old 02-10-2017, 07:55 PM
Welcome Martin,
Great looking bike!
post #4 of 10 Old 02-10-2017, 09:05 PM
You are scraping the foot pegs because you are not leaning off the bike properly and instead forcing the bike to lean for you. Work on body positioning and you will find that it alleviates a lot of the problems you are having not only with the foot pegs, but the suspension as well.
post #5 of 10 Old 02-11-2017, 03:57 AM Thread Starter
Generally agree, but if you are judging by the pictures, they are quite old. I have since improved a lot in both body position and pace.
On the other hand stock 954 forks are notoriously undersprung and is not possible to set correct sag even with max preload. Hopefully with proper springs, things will be much better overall.
post #6 of 10 Old 02-11-2017, 04:35 AM
Hello and welcome!
post #7 of 10 Old 02-11-2017, 04:51 AM Thread Starter
Thanks guys.
Forgot to mention:
- stick coils from a gixxer 1k
- freeflow air filter and exhaust
- dynojet jetkit
- -1/+2 sprockets
post #8 of 10 Old 02-11-2017, 08:52 AM
Springs will certainly help get the sag correct, but the dynamic relationship with the geometry in motion is more controlled by the valving. When you trailbrake into the turn while simultaneously carrying the most lean angle the damping is what controls how much dive you get out of the forks. It won't be enough to just do springs. At the very least do a full 20mm piston kit. I don't remember if the 954 forks have a topout spring, but I believe they do which can easily be modded as well.
post #9 of 10 Old 02-11-2017, 09:20 AM Thread Starter
I have the forks in pieces right now, no topout spring.
Honestly, trying to get somewhat decent suspension performance with minimal cost, while saving up for a modern bike for track duty.
Read that you can get decent results modifying the shim stack on the stock valves, do you have any experience with this?
post #10 of 10 Old 02-11-2017, 11:41 AM
It can be done, but you need to be prepared to do it over & over again many times until you get the results you want if you want a truly beneficial improvement rather than just something different than what you already have. Then again even a very minor improvement is still an improvement...
