Go Back   Wrist Twisters > Motorcycles > Adventure Riding
Join WristTwisters Today
Old 03-09-2010, 09:42 AM   #1
KLR 650 musings.
As some know, I have an 05 Kawasaki KLR650. It has more than a few mods in it and it's got now 21,000 miles on it.
Recently I purchased a new set of sprockets, a chain and a couple Pirelli MT21 RallyCross tires for it. Having run Metzler Karoos for ever on this thing, I thought I'd go with a new brand and different rear tire size. Stock is 120/90-17 and I chose 130/90-17 which is visibly taller but of the same width and roughly the same pattern as the Karoo. It is about 90% dirt and 10% street.
Quite sometime back I switched counter shaft sprockets and went with one tooth up at 16 rather than stock 15. Reasoning being that at highway speeds, I wanted to drop the motor RPM some and did so to the tune of about 6%.
Now, with the higher profile rear, I made a calculation of the theoretical top speed of the bike. At 5000 RPM, the speed was indicated at 80. With a redline of 7500, the indicated top speed would be 120 if it had enough power to pull it which it doesn't. Given that the speedo is about 10% off, the true top would be 108.
This bike of mine is lowered 1" in the interest of making it less of a 'sail' in crosswinds. This has worked out perfectly and I have one of the best testing areas for this 15 miles up the California coast from my house at this place called Gaviota. I was there just yesterday trying the bike out with the new skins. These Pirellis are super slick when new. They do feel excellent on the slab at 75 to 80 actual. This is very good because I want to stay with this type of tire even when I hit longer distances on the street.
I did have to modify the chain guard on the bandsaw in order to have this knobby profile not interfere but it came out excellent.
The following are the mods I have on this bike:
1) K&N air filter, drilled out airbox
2) Oversized front rotor
3) Progressive fork springs
4) Progressive 420 rear shock
5) Dual Star lowering links, shortened side stand, anti puncture shift lever(saved the case already on 1 occasion but destroyed the shift lever so yup, I bought another!)
Radiator guard(saved the radiator, still in great shape, plastic rad/side cover bit the bag)
billet rear brake pedal mount(will not crack or shatter on impact), water pump guard, and rear master cylinder guard.
6)Galfer SS lines front and rear.
Now..........thoughts on the future:
I think the Kwak KLR could very well be the perfect adventure bike with the right approach. This approach for me would be as follows:
I would start with a brand spanking new KLR 650. I would break it in as I did this one: FAST. During this time I'd evaluate the new forks and front brake along with the rear shock capability. If I found the improvements to be satisfactory, great! I'll have more money for the motor. If not, same treatment as my current bike above.......new rear shock, lowering links, progressive springs and oversized rotor. (This mother foiker really does stop, massively!)
Next, I'm looking at this 705 big bore kit.
Performance Projects: Kawasaki KLR 685 & 705 Kits
To this I'd couple a complet exhaust system/air filter with a dyno-tuned re-jet. Yes, I'd dyno it first. Can't lose the opportunity to really cover these mods.
Then, I'd add the ruggedizing features above to the radiator, side cases, shift lever etc.
Next would be the rear luggage rack and quick remove fasteners. A larger wind shield is a must.
Finally, I'd definitely add the higher profile rear tire (130/70), the 16 tooth front and a two tooth smaller rear.
Now, this bike would be happy all day long at a true 80 mph.
I am actually seriously considering this, bouncing it back and forth in my head. I've got to do some more research on the big bore kit. Somewhere stuck in my mind is this desire to pull the crank and have it balanced and welded. This would add a huge measure of reliability to the bottom end.
Thoughts, ideas, observations welcomed.
My President is anally poking your child's future.
Change you can feel!
Old 03-09-2010, 10:20 AM   #2
Tirone is my middle name
mattf's Avatar
If I remember correctly wasn't there someone on here talking about doing the big bore kit, can't remember who or if they actually did it though. Thumpertalk would probably be a good place to research that part of the equation though. good luck with your musings.
'08 Yamaha WR290R/X
'09 KLX140L (wifes bike)
mattf is offline   Reply With Quote
Old 03-09-2010, 11:28 AM   #3
Das Kalmar
gert260's Avatar
This thread right here......useless without PICS!!!!!
BOOM CHICKA
gert260 is offline   Reply With Quote
Old 03-10-2010, 07:30 AM   #4
I rode the KLR yesterday again in some radical wind. I just got a bit lower in the saddle and held it at an indicated 85-90. I was thinking of what it would be like with a couple less rear teeth. Mmmm mmm good I bet. Too late for this bike, having bought the new rear sprocket and installed it already.
I'll see if I can scare up a couple of pics for you gert. Gotta keep in mind she's a 21,500 mile old girl, though. But jeeze she ran smooth yesterday! Those Pirellis seem pretty damn nice to me so far. Real easy steering, yet fairly stable at speed.
Old 03-07-2011, 11:08 PM   #5
Carp Killer
Wallybanger's Avatar
A buddy of mine had a KLR with a KTM inverted fork swap! Looks WAY better and he said it beat the absolute crap out of the stock forks. Might be something to consider if you want to dump a whole bunch of money into a custom bike
Wallybanger is offline   Reply With Quote
