Go Back   Wrist Twisters > Motorcycles > Adventure Riding
Old 06-26-2011, 12:20 AM   #1
Close call
Close call on the DRZ Sm today. Total loss of front brakes as I came into a corner. Saved it with the rear and a bunch a downshifts in the last second. As it turns out, your life does flash before your eyes. Luckily these things don't do much more than 100 kph.
Upon inspection I discovered my front braided line had worn through where it was contacting the front tire at the bottom of the fork stroke. Wore clean through the braided housing and the plastic line under that... Dumb mistake on my part. Avoid it if you can. Use the right length (this was a tad long as I have the triples dropped a bit on the forks), route lines well and secure them, make sure nothing rubs.
honda ng gingsa is offline   Reply With Quote
Old 06-26-2011, 09:00 AM   #2
wow, glad ur ok and you didnt panic! good job. get that brake line fixed!
Old 06-26-2011, 09:09 AM   #3
NWTB Non Stinky 919
jeffie7's Avatar
Glad you made it around that turn!
Sometimes its the little things that add up to really big things.
www.handsonkitchen.com
jeffie7 is offline   Reply With Quote
Old 06-26-2011, 06:14 PM   #4
Glad you made it through that.
Old 06-27-2011, 04:49 AM   #5
That could have been really bad.
Old 06-27-2011, 09:04 AM   #6
Commuderator Munity
Good thing the brake fluid didn't spray out on your tire. Otherwise.......
2006 Honda VTX 1300C (traded)
