I have never worked on a shaft drive or hydraulic clutch bike before. I want to change all fluids.
First the hydraulic clutch. Do you bleed it just like a brake? On a brake you feel resistance before the lever hits the bar-so how do you do a clutch? I have done brakes many, many, times--more than I cared to.
Now the shaft drive--the rear "differential" where the rear sprocket would be looks pretty obvious, drain in the bottom & fill it up until it runs out the fill hole I assume. My question is: is there a separate reservoir up where the front sprocket should be or is that just bathed in engine oil? I dont see a drain plug there.
