Join WristTwisters Today
Old 01-26-2008, 06:22 PM   #1
(oYo)
2000TJ's Avatar
Speed Bleeder Part Number
Can anyone confirm that SB8125L is the right size/model Speed Bleeder for an '06 919? I've reviewed the manufacturer's site, just looking for confirmation.
Has anyone found the seal on the Speed Bleeders to fail after multiple uses? I see they sell the sealant for this reason.
Thanks
http://speedbleeder.zoovy.com/catego...ley%20Davidson
2000TJ is offline   Reply With Quote
Old 01-26-2008, 07:04 PM   #2
Sixty-9er
edgecrusher4444's Avatar
I've used speed bleeders on my old yamaha for a few years now with no problems. Easiest way to take a empty line to nice and full, and keep the fluid fresh.
edgecrusher4444 is offline   Reply With Quote
Old 01-27-2008, 06:42 AM   #3
You can use the SB8125 or the SB8125L. Both bleeders are 8 mm x 1.25. The 'L' is easier to attach tubing. Depending on the usage it can't hurt to buy the sealant.
Mike's Bikes
Old 01-27-2008, 08:12 AM   #4
(oYo)
2000TJ's Avatar
Thanks for the info gents.
Now, I have bleed brakes and clutches by the traditional method, but I have never completely removed a bleed screw/valve. Should I expect the fluid to come rushing out? I assume leaving the reservoir cover in place would minimze this, any input?
Thanks again.
Old 01-27-2008, 08:16 AM   #5
Ken
Community Admin
Ken's Avatar
Hey TJ - I bought speed bleeders for my 919 before I traded it in. They were never installed and are sitting in their packages in the garage. If you are interested in them, shoot me a PM.
2009 Honda Goldwing
Ken is offline   Reply With Quote
Old 01-27-2008, 08:52 AM   #6
Thanks again.
Nah...A little might dribble out, protect the caliper with a paper towel and do you best at a quick change. Just don't squeeze the brake lever.
Mike's Bikes
Old 01-28-2008, 06:41 PM   #7
(oYo)
2000TJ's Avatar
PM sent
Old 02-06-2008, 05:18 PM   #8
(oYo)
2000TJ's Avatar
The deal is done! Will try to install this weekend if I can shovel out the door to the garage...
Old 03-09-2010, 04:30 PM   #9
ホンダ919
I know this is an old post... just thought I'd bring it back instead of creating a new thread.
Do you need their thread sealant or will Teflon tape do the job?
andrewebay1 is offline   Reply With Quote
Old 03-13-2010, 08:48 PM   #10
(oYo)
2000TJ's Avatar
Andrew, there is no need for any thread treatment given normal use (ie, 1 or 2 manipulations per year).
I would NOT even think of using tape.
