Join WristTwisters Today
Closed Thread
Old 05-31-2006, 06:27 AM   #1
Thumbs up Helpful Topics for 919 owners
Links
919 Service Manual - 88MB Adobe PDF
919 Specifications, Maintenance Tips, and How-To's
919.org
Conversion Calculator
Alerts & Helpful Tips
http://www.wristtwisters.com/f94/919...ight=passenger
919 Valve shims are available to all members
Apply a dab of blue Loctite 242 threadlocker to the threads of Items #16 and Item #12. These bar end screws and shift lever bolt have been know to vibrate loose.
- Item #16
- Item #12
Chain Adjuster Alert
Gas fouled plugs - Check the FPR(Fuel Pressure Regulator)
Engine mounted frame sliders - Not recommended!
Maintenance/Helpful How-To's
.General
General Maintenance/How-To
Alternator/Stator cover Replacement Thanks go out to Nemo for this How-To
Body - Grab Handle Mounting Pad Removal/Fill How To: Thanks go out to 9nineteen for this How-To
Body - Repainting the 2002 -2004 engine side covers. Courtesy of 9nineteen
Brake bleeding using marylandmike's homemade brake bleeder.
Brake bleeding using robtharalson's procedure.
Broken exhaust bracket - How To Fix.
Clean and shine your head pipes
Checking for bent fork tubes and front end realignment
Clutch adjustment
Clutch switch fix
Flywheel - Removal Thanks go out to bucky for this How-To
Front wheel installation
Fuel Pump - Troubleshooting
OEM - Mirrors - RH/LH Threads Explained
OEM - Tool Kit:
Removable Centerstand for servicing the 919 + Where to buy it.
Repacking Sato Slip-ons. Thanks to Nemo
Self Diagnostic Reset Procedure:
Steering stem/triple clamps bearing - Removal & Installation
Stock bar ends and anti-vibe assembly - Removal.
Throttle - Free Play Adjustment
Valve Clearance Specs
Valve Clearance procedure with photos (Detailed). Courtesy of Sokali
Water Pump - Removal & Installation
Wheel Bearings - Repacking Thanks to Hasbeenracer
Winterize
Wiring diagram
.Chain
- Chain length calculations/Chain selection
- Chain Maintenance and Cleaning:
- Chain - How To Adjust.
Modification How-To Links
.General
Bafflectomy
Frame Sliders - Relocation
Handling - Raise your fork tubes
Modified OEM Center Stand. Thanks to Motocycho.
Power Commander installation
Installing Dominator Dual Headlights with Running lights. Thanks go out to Sgt_Mojo for this How-To
Stainless Steel Brake Line Installation with Pics (Galfer Example)
Suspension - 04 parts swap for pre '04 forks
.Electrical
- 12 volt Auxiliary Power Outlet Installation
- Installation of new turn signals
- Convert 2 wire LED's into combination blinkers/running lights
- Installing Dominator Dual Headlights with Running lights. Thanks go out to Sgt_Mojo for this How-To
.PAIR System
- Where to buy Pair Block Off Plates
- PAIR system removal / block off plate installation
- PAIR System Removal and Spark Plug Replacement Tips
Electronic flashers to slow down the blink rate
CustomLED
vfxkits
Clear Alternatives Not recommended!
Must read Wrist Twister threads
Centerstand mod./Evaporative Canister removal
Exhaust Modification Options including 900RR
Official 919 Exhaust Stink thread
Fuel Injection (FI) system overview
Future caliper swap
Gearing and chain discussion
Sato Slip-on cans - Installation
Stainless Steel Brakelines - Where to get the best price.
Where to buy 919 windscreens
Where to buy OEM Honda parts for your 919.
Important Specifications:
Handle bar dimensions, OEM and aftermarket
* All years have seven position spring preload adjustment on rear shock
* All years use 43mm front forks
* Stock Mirrors: The OEM Honda mirrors are both 10 mm x 1.25 left hand threads. They screw into OEM Honda adapters which are also 10 mm x 1.25 left hand female threads. The male threads on the adapter are 10 mm x 1.25 right hand thread and they screw into the handle bar mounts.
Lighting specifications
.Drive-train
- Stock chain size is 530 with 114 links (many shorten to 112)
- Stock drive (front) sprocket - 16 tooth
- Stock driven (rear) sprocket - 43 tooth
Model Year Changes:
2002: First year
2004:
Adjustable preload and rebound damping added to front fork
Adjustable rebound damping added to rear shock
Chrome gauge package
2005:
Adjustable preload and rebound damping for front forks
Adjustable rebound damping for rear shock
Black valve cover and right and left side case covers
Gold calipers
Metallic black
2006:
Black valve cover and side covers retained
Gold calipers retained
2008:
The end of the road!!! The 919 is discontinued.
Feel free to comment or add addition information that will be helpful to potential or new owners of the 919.
Mike's Bikes
Old 05-31-2006, 06:43 AM   #2
Signifer
Went to gold calipers in 04?
Added extra seat hooks in 04?
Added clock in 04?
Bryce919er is offline
Old 05-31-2006, 07:48 AM   #3
BockHawk's Avatar
Hey, back off man! I did my best to gather that info in about 5 minutes! j/k
Thanks for the heads-up, I knew I wasn't going to get everything in there.
2003 919 27,000 miles
BockHawk is offline
Old 05-31-2006, 09:29 AM   #4
no, I don't drive a VW
mudarra's Avatar
The 05 has adjustable preload and rebound damping on the rear shock.
DOH! never mind, just read the note at the bottom
Larry
mudarra is offline
Old 05-31-2006, 10:08 AM   #5
Good idea, mucho helpful for lots of people
Old 05-31-2006, 11:46 AM   #6
Church of the Holy Smoke
MotoCycho's Avatar
Added clock in 04?
My '03 came with double set of seat hooks. Anyone else with an '03 confirm?
- Rev. CYCHO -
MotoCycho is offline
Old 05-31-2006, 01:07 PM   #7
WTF my '03 only has one set unless I'm blind...
dadogs is offline
Old 05-31-2006, 01:10 PM   #8
Originally Posted by m51142
2003:
Matte black
"Smoke" (looks like grey to me)
You're looking through the wrong lenses on your bifocals it's "smoke"
Also Mike a very comprehensive and informative list. You da man!
dadogs is offline
Old 05-31-2006, 01:22 PM   #9
BockHawk's Avatar
My '03 also has one set. I believe they went to two sets on the '04.
BockHawk is offline
Old 05-31-2006, 03:40 PM   #10
MotoCycho's Avatar
well... my '03 had the two hook set (4 hooks) with the sideways entry for the owners manual pouch and the pedestal under the passenger section for extra support against the frame I assume so the seat pan doesn't crack under your passenger. Incidentally, the PC3 install instructions show them mounting the PC3 right where the seat pedestal sits.
PICS:
Seat on left came on my '03. Seat on right I got off eBay and I sent to Sargent for recover.
Where I mount the PC3 instead.
My guess, my seat was switched at the dealership. Maybe the seat I bought on eBay was the original off my bike? It looked new and completely clean except for a small hole punched in the top. Most likely a showroom floor incident. It was the perfect candidate for a Sargent recover, that's for sure.
- Rev. CYCHO -
Closed Thread
