Old 10-01-2006, 06:18 PM   #1
motoxer101
Guest
Posts: n/a
919 Broken lower exhaust mounts..help
Has anyone had an issue with a broken bottom exhaust mount tab on their Honda 919's? I installed some Sato's and noticed the bracked is broken. This tab is welded to the bottom of the frame. I installed a strap to support it, and honestly it didn't seem lose at all without it, but wondered if this is common.
Also, installed a set of SATO slip ons with any other mods and the bike runs killer. I rode about 100 miles yesterday, no popping, no running hot, just killer tone and a little more giddy up.
Any feedback would be appreciated. R
Old 10-01-2006, 09:18 PM   #2
Heavy Metal
ratdog's Avatar
yeah...it breaks, happens to some
satos or no satos...
let's see, mines been that way about 10,000 miles...i guess i really should fix it
u can maybe get it fixed under warranty...some have
don't know about strappin it though...
ratdog is offline   Reply With Quote
Old 10-01-2006, 09:33 PM   #3
motoxer101
Guest
Posts: n/a
Thanks for the reply. RD How many miles do you have now? It is super sturdy, so I am not sweating it.
I can send a pic O' the fix if anyone is interested.
I ordered a Jardine fender eliminator that allows stock signals.....next sat's pre-ride project.
R
Old 10-01-2006, 10:06 PM   #4
Heavy Metal
ratdog's Avatar
damn, i don't actually know without lookin haha...i'll check in the AM (i'll ballpark it at 15k)
post the pic of the fix, would like to check it out
what the $ on the jardine setup?
(we'll be needin pics of the completed install as well )
really like the idea of keepin stock signals and would like to check out how it looks when u'r finished...
i've received too many complaints from other riders regarding the LED setups, not bright enough during the day. i'm converting my LED's to running lights and re-installing some DOT signals (R6 or Shinkos...have both, just need to decide)
Old 10-01-2006, 10:24 PM   #5
ajcombs's Avatar
Helping a Member in Need
+1 with ratdog would love to see pics with the stock signals. I like the look of the Led lights just that they are hard to see, even some that are stock are hard to see.
ajcombs is offline   Reply With Quote
Old 10-01-2006, 10:32 PM   #6
motoxer101
Guest
Posts: n/a
will do guys. I am all about safety, and smaller signals are not going to add to performance....DUH. cooler? yeah, but hey, I ride in L.A. Calif!! in prime commuting time.....SAFETY!
Anyhoo...I have talked to Jardine and this part is a "no cut, bolt on" install. I have not seen one installed but, you can see the part on the website.
http://jardine.rideshop.com/catalog/...oducts_id=1659
any feedback/experience???
Old 10-02-2006, 04:16 AM   #7
I had the same problem also with my 2002, and I made a bracket that bolts onto where the centre stand would mount to the bike, and then I just used a spacer and a longer bolt to again support the exhaust.
Hope this helps
regards
Cory
CB900F2 is offline   Reply With Quote
Old 10-03-2006, 11:04 AM   #8
motoxer101
Guest
Posts: n/a
It does thanks. Do you buy any chance have a pattern of that bracket? Thanks, Rod
Old 10-03-2006, 11:09 AM   #9
Heavy Metal
ratdog's Avatar
anyone who wants....forward me the pattern and i'll fab up a dozen
Old 10-03-2006, 12:41 PM   #10
drivit's Avatar
Talking
puddle jumping, stunting or beer will damage that support. the bracket fix is nice, in case you get it welded UNPLUG the black box.
drivit is offline   Reply With Quote
Old 10-03-2006, 01:26 PM   #11
Heavy Metal
ratdog's Avatar
+1
dude, was it u that fried one?
Old 10-03-2006, 01:32 PM   #12
BockHawk's Avatar
Originally Posted by ratdog View Post
+1
I thought it was jin that had all the problems, but later found out it was a vacuum line causing his problems. I might be wrong about that.
2003 919 27,000 miles
BockHawk is offline   Reply With Quote
Old 10-03-2006, 03:37 PM   #13
Not a problem, I'll scan my paper jig and post it, hopefully when I post it, it will be too scale..
Old 10-03-2006, 05:43 PM   #14
motoxer101
Guest
Posts: n/a
Very cool. Thanks.
Old 10-03-2006, 06:17 PM   #15
Unbannable
Super Sneaky Steve's Avatar
So, you take off your giant plastic shovel then put on a giant metal one? And pay $86 in the process? Doesn't make sense to me.
You should have bought the official SSS fender eliminator!
Super Sneaky Steve is offline   Reply With Quote
Old 10-03-2006, 08:03 PM   #16
motoxer101
Guest
Posts: n/a
SSS....hmmm. It is much smaller, thus lighter and more compact....without giving up safety. Also drops a couple pounds. Now I know that may seem like nothing, but when you add removing the smog can; -2lbs, changing cans; -9lbs, AFAM bars; -1 lb, and the additional HP; +/- 4hp...thats -12lbs, and + 4hp. Good trade off. Efficiennt, and safe. Trust me, I ride it the worst possible conditions, traffic wise....
Sorry...I vented...ok. I will take bigger, heavier turn signals for the safety they provide. Its not like you are going to outrun me anywhere because of smaller signals...make sense????? sometimes cool is not cool
Old 10-04-2006, 04:54 AM   #17
Unbannable
Just for the sake of discussion (it really doesn't matter) but I'm not sure that metal thing is lighter than the plastic thing.
I can understand wanting larger signals. I like safety too, but the Integrator kit actually makes the blinking area larger and brighter than stock, better looking too. If I were dead set against it, I would try to just cut up my plastic one. That's what I did on my last bike.
Old 10-06-2006, 03:37 PM   #18
Hey guys.. Here is a scan of my paper template I made..
Hope it helps
Old 10-06-2006, 03:58 PM   #19
motoxer101
Guest
Posts: n/a
Thank you!!
Old 12-01-2007, 03:40 PM   #20
Ok, sorry to bring back a somewhat dead thread but I need advice. My lower exhaust mount is broken completely off, I mean you can see the u where it is welded to the exhaust but the other half of the circle is gone(top part). I can make that bracket describe earlier in this thread but have nothing to bolt it too on the exhaust, any ideas?
mrjason is offline   Reply With Quote
Old 05-19-2008, 07:00 AM   #21
jclong74's Avatar
Just got back from my first trip to Deals Gap, it was bada$$. Slayed the Dragon & surronding roads. Anyway, I was looking the bike over after the trip & found a broken exhaust bracket. Took it to the dealer on Sat, trying to get it fixed under warranty(got the bike new last March). The mechanic said the rep would have to look at it. He doesn't think Honda will fix it, so looks like I'm getting to fight w/ Honda to get it fixed. I'm glad that others have had the same problem gives me a little ammo. I'm supposed to find out today what they say. I'll keep you posted.
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline   Reply With Quote
Old 05-19-2008, 07:06 AM   #22
jc - Any mods. or bone stock?
Mike's Bikes
Old 05-19-2008, 08:05 AM   #23
Heavy Metal
ratdog's Avatar
Honda "should" fix it...
I've ignored the problem for the last 10-15K miles w/o an issue. I'm not going to worry about fixing the little, hardly useful tab on the bottom, it'll probably just break again.
Wonder if it's the general chasis flex that's breaking them off. All fat guys and two up riders should check in.
GL today
Old 05-19-2008, 08:13 AM   #24
(oYo)
2000TJ's Avatar
2000TJ is offline   Reply With Quote
Old 05-19-2008, 10:30 AM   #25
jclong74's Avatar
Yosh Exhaust, thats it. Put the stockers back on before it went to the dealer.
2006 919 (Sold)
2011 Cb1000r
Old 05-19-2008, 12:05 PM   #26
Naked in Cheese Land
Anti-Shadows's Avatar
Mine been broken for quite while too. still stock. 220#
Seems to be the only thing on the thing that isn't bulletproof.
Anti-Shadows is offline   Reply With Quote
Old 05-28-2008, 10:24 AM   #27
jclong74's Avatar
Got my bike from the dealer. They didn't fix the broken bracket. Said Honda wouldn't do it because of the milage, (it only has 12k), but I'm getting new mirrors. The silver around the outside failed. Honda said they have had complaints about the mirrors but not the bracket. I told them that a few people on the site have had issues but they didnt do anything. O well at least I tried.
2006 919 (Sold)
2011 Cb1000r
Old 03-05-2011, 07:11 AM   #28
mambomonster's Avatar
Bringing back an old thread - anyone willing to make a bracket for me? I just discovered that my exhaust mount is broken.
mambomonster is offline   Reply With Quote
Old 03-05-2011, 07:22 AM   #29
Mr.t81 had the same issue and is making a bracket. Mine has been broken for years. I talked him into making me two. You could try him.
rickard919 is offline   Reply With Quote
Old 03-05-2011, 09:42 AM   #30
I'll shoot him a PM, thanks.
Old 03-05-2011, 10:15 AM   #31
Tirone shoelaces
TexasTraffic's Avatar
Mine is also broken (stock exhaust).
I think it happens to all 919s, sooner or later. Mostly sooner
TexasTraffic is offline   Reply With Quote
Old 03-05-2011, 10:19 AM   #32
Gees, he could have a small business going here soon.
Old 03-05-2011, 07:15 PM   #33
919 aka Hornet 900
Mr T81's Avatar
Here is what I came up with.
Sorry I can't make brackets for everyone, all I have is a grinder, a bench
grinder, a hand drill and a few files.
I can't start mass-producing brackets because I won't have any time left to
work on my own bike.
Notice how far the hole on the header is from the hole on the original bracket.
Mr T81 is offline   Reply With Quote
Old 03-05-2011, 07:30 PM   #34
Looks good, could you trace it out and post it please, could come in handy...
rmb is online now   Reply With Quote
Old 03-05-2011, 08:37 PM   #35
Once I get one I can bring it in and get them cut by water jet. Not sure of the cost but I would offer them up at cost+shipping just like the pairs cover plates. If Mr.t81 is alright with that.
Old 03-06-2011, 06:00 AM   #36
Cool! Mine's not broken but I'll but one to have just in case. I figure if I have one the mount will never break...
Old 03-06-2011, 06:35 AM   #37
Those pictures look great to me. That bracket will be stronger than the skinny tab that breaks. I'll take one now and a water jet cut version too - will store it as a spare.
Old 03-06-2011, 07:50 AM   #38
919 aka Hornet 900
Mr T81's Avatar
Water jet cutting would be the perfect tool to use to mass-produce the brackets. Meanwhile I have enough steel left to make 3 more. I will cut the steel to size, tack the 3 pieces over top of each other with the welder at work on monday and shape the 3 pieces at once. Rickard can have two
and mambomonster can have the last one.
I will send a spacer with the brackets, for mine it's 11/16" long (notice the original bracket was cut off) I will not weld it on the bracket since the length of spacer your bike needs might be different.
Old 03-06-2011, 07:52 AM   #39
919 aka Hornet 900
Mr T81's Avatar
Somebody already did, post #18
Old 03-06-2011, 07:54 AM   #40
Hmmm, I now realize I must check to see if mine has cracked and failed.
Just checked.
Mine is still intact.
Now rickard is going to slag me for not riding it enough - and he's right !
