Go Back   Wrist Twisters > Wrist Twisters > Classifieds > Want to Buy
Old 06-28-2011, 02:07 PM   #1
Seņor Calamares
applespeed's Avatar
WTB: 919 HANDLEBAR RISERS, REAR BRAKE LEVER?
Looking for 919 bar risers, 7/8", and rear brake lever, thanks.
applespeed is offline   Reply With Quote
Old 06-28-2011, 02:24 PM   #2
I'm actually in the market for some as well and done a little searching. But it seems there are two kinds people have tried successfully:
TwistedThrottle.com : Handlebar risers (BMW, Ducati, Kawasaki, KTM LC4, Gas-Gas, Honda, MZ, Suzuki, Triumph, Yamaha), rise height of 20mm, 25mm, 30mm or 50mm - by SW-MOTECH - LEH.00.039150
And then these, which go back and up:
GenMar Mfg Handlebar Risers 7/8" Univ - 1" Up 1-3/8" Back Black
andrewebay1 is offline   Reply With Quote
Old 06-28-2011, 02:39 PM   #3
Seņor Calamares
applespeed's Avatar
i was hoping someone had a set of those up-and-backs... which one are you planning to get?
Old 06-28-2011, 02:50 PM   #4
I haven't figured yet, just did the research on my lunch break. But I'll be measuring later on and see what fits well with the Corbin. I'm thinking that up and back will work well for me as well, but I'm worried if the cables will reach. Maybe have to ask curiosmike, he's running them.
I did an all-day last Saturday and the combination of higher seat position and low bars strained the crap out of my lower back. And I'm not old enough to have a reason to complain yet.
Old 06-28-2011, 02:55 PM   #5
Seņor Calamares
applespeed's Avatar
lol.
I figure removing/re-installing risers is easier than switching back and forth between ULs and stockers...
Old 06-28-2011, 04:24 PM   #6
curiousmike's Avatar
I'm running them, without stock bars.
No issues as they are.
I don't have stock bars, so I'm not sure how much more slack the cables would need.
curiousmike is offline   Reply With Quote
Old 06-28-2011, 04:29 PM   #7
arctic954's Avatar
It depends on the bars that you have.......
If you have a ton of sweep back.....get the straight up risers.
If you are running a straight bar and want it comfortable for long trips.... get the up and backs.
I have the Tharbars and like to run them pretty straight.....the up and back are the way to go with Rob's bars.....
arctic954 is offline   Reply With Quote
Old 06-28-2011, 04:51 PM   #8
I have risers that are 1" up and 1" back, the cables work but are taught, I don't think you could go any more than that with stock cables.
Old 06-28-2011, 05:05 PM   #9
My biggest concern with this would be the brake lines - if you have stock brake lines, either it will work or it won't.
With aftermarket lines, you'll have to worry about fork extension ( i.e., hard acceleration ) using up line length.
Old 06-28-2011, 05:11 PM   #10
Thanks for the input gentlemen. I have something similar to Renthal lows or regulars, so it's looking like 1 up and back will probably fit the bill. As for the brake lines, I have some SS that are a bit long so no problems for me there.
Old 06-28-2011, 08:27 PM   #11
Batman
velodesign's Avatar
I want risers for the stock bars! Put them on to get out of the flat dakotas cuz were flat, take em off when I get to the twists in Minnesota / Wisconsin
***Need someone to do some photoshop mockups for you? Looking for a new color or pallet for your ride? How about part mockups, Photo restoration, retouching or color correcting your pride and joy to hang up in the office / man cave? I offer all of the above services to WristTwister members. PM me for details! ***
velodesign is offline   Reply With Quote
Old 06-28-2011, 09:39 PM   #12
As a side note, I notice no adverse handling from the new bar position.
I asked the guy I bought them from if he noticed different handling, and he said he did... a little.
I'm knee down without issue. I've acclimated. I love 'em.
Old 06-28-2011, 10:53 PM   #13
still jonesin
Lightbulb Brake pedal
I'll sell you this one $10 shipped
It's straight but has about a 1/4 inch grind mark on the bottom.
ideajones is offline   Reply With Quote
Old 06-29-2011, 02:35 PM   #14
Seņor Calamares
applespeed's Avatar
ideajones! thanks! i'll send pm later for details.
Old 08-14-2011, 10:33 AM   #15
Seņor Calamares
applespeed's Avatar
i found a brake lever locally. thanks guys!
Tags
919
