Go Back   Wrist Twisters > Wrist Twisters > Classifieds > Want to Buy
Old 08-14-2011, 12:17 AM   #1
WTB: 919 Front Wheel, Stock Rear Rotor
Seems the PO slightly tweaked my front wheel. Anyone out there got a good used stock front wheel?
Also looking for a good used stock rear rotor.
CB700S is offline   Reply With Quote
Old 08-31-2011, 03:19 AM   #2
Alternately, can I swap in an F4i wheel?
Old 08-31-2011, 01:13 PM   #3
Commuderator Munity
Not sure about the F4i, but with with a little modification you can swap in an F3 wheel. You just need one of the spacers from the F3 wheel, both from the 919.
Do a search on here for F3 front wheel, you'll find a few threads. You have to shim in your calipers with some stainless steel washers, but it is a fairly easy swap. A 900RR rear wheel is even easier - cush drive is plug and play, as well as rotor and caliper.
Just make sure you machine down (use something perfectly flat) the F3 spacer to exactly .045". I tried putting mine on with the stock width and it was throwing off my calipers too much.
2006 Honda VTX 1300C (traded)
Old 08-31-2011, 01:14 PM   #4
Commuderator Munity
Here is a pic of mine with the F3 front (10 button rotors) and 900RR rear.
Old 09-30-2011, 12:32 AM   #5
Still looking for a rear rotor, anyone got one?
Old 12-24-2011, 06:41 AM   #6
Bumping again...
Old 12-26-2011, 07:24 AM   #7
Got the rotor, still looking for a wheel.
Old 12-26-2011, 12:02 PM   #8
Pm sent, I got a spare rim.
'02 CB919
"The large print giveth, and the small print taketh away"
Tom Waits
HeliMech is online now   Reply With Quote
Tags
919
