Go Back   Wrist Twisters > Wrist Twisters > Classifieds > Want to Buy
Old 08-21-2011, 06:51 AM   #1
Boskru's Avatar
Givi racks
I am looking for a set of GIVI tubular side case racks and the top case rack that is required for mounting the side racks. Hoping for a good deal.
Boskru is offline   Reply With Quote
Old 08-21-2011, 10:11 AM   #2
There's a set of side case mounts on fleabay right now
http://cgi.ebay.com/ebaymotors/Givi-...item2566d9da1d
http://cgi.ebay.com/ebaymotors/GIVI-...item588f6a7007
voodooridr is online now   Reply With Quote
Old 08-21-2011, 02:32 PM   #3
Serial Monogamist
ST-DocLizard1's Avatar
Assuming that you have stock exhaust. Getting a Givi set to fit is not that much of a problem, finding one could be. The directions are a little sketchy, but passable. If you are running aftermarket undertail/exhaust, you may have a problem with fitment. You will also need the standard rear fender assembly for Givi. You may want to try SW-Motech at Twisted Throttle for an alternative.
Doc
ST-DocLizard1 is online now   Reply With Quote
Old 08-21-2011, 02:39 PM   #4
Serial Monogamist
[QUOTE=voodooridr;463852]There's a set of side case mounts on fleabay right now
Givi Top Rack for Honda 919 (Hornet, CB900F) | eBay
This is a modified top rack and not really compatible with Givi side racks as stated in the description. The arms have been shortened to accommodate an aftermarket/undertail exhaust. Good for a top box only. That is a Givi Monokey Top Plate installed.
The side rack system in the second link looks fine.
Doc
