Go Back   Wrist Twisters > Wrist Twisters > Classifieds > Classifieds Archive
Old 03-24-2010, 08:38 PM   #1
bwoso's Avatar
WTB: Single (left side) slip on exhaust can for 919.
I am only using the left side exhaust can, and the stock can looks like crap from the back side. I want something that is more or less straight through that will create as little back pressure as possible, but I am sure any after market can will work fine.
Brandon
bwoso is offline
Old 03-24-2010, 09:34 PM   #2
i have a single exhaust two brothers with around 1500 miles i would part with im wanting to try out the yoshi's let me know if interested just pm me thanks....charles
TROYAIK88 is offline
Old 03-24-2010, 09:41 PM   #3
So am I right - you have blocked off the right hand muffler and are only running the gas through the left stock pipe? If you are still using the stock Y pipe then you'll be strangling the poor exhaust gasses trying to shove them through half the diameter pipe required.
What you are after is available in a tidy unit from Two Brothers - it is however a right side can, but I am sure you'll live with that - when riding just wear your penis on the left to equal the weight distribution.
Old 03-24-2010, 09:44 PM   #4
lmao some inside story to this or what???id like to hear it
Old 03-24-2010, 09:46 PM   #5
my exhaust is identical to that one ,but is carbon fiber by the way looks perfect and sound good too.later....charles
Old 03-25-2010, 08:54 AM   #6
bwoso's Avatar
I have the turbo system from WAVE, and the setup I have is for one pipe. I can put the stock right pipe on just so it looks stock, but I don't like the fact that it is just a heavy hunk of metal with no use. So, right now I have the stock left can all hollowed out, but it looks bad from the right side of the bike since it not supposed to be looked at.
So, I was hoping someone laid a bike down on the right side and bought a new system and still has a left can lying around.
D&D said that they will sell me one can, but I have to buy the two pipes from y pipe to cans, and shipping is expensive. I am not planning on spending a bunch of money on this since it is just a cosmetic thing.
bwoso is offline
Old 03-25-2010, 08:56 AM   #7
thats cool good luck in your search....charles
Old 03-25-2010, 03:40 PM   #8
Just search E-bay for a used can off a litre bike. You'll probably need to organise an adaptor between the joins.
Also check Denniskirk.com outlet shop for closeout prices on slip on mufflers - they often have new cans really cheap. And Two Brothers site also has a specials section.
Old 05-24-2010, 09:11 PM   #9
Topher919's Avatar
Hit up Mark at Black Dragon Exhaust >>>> Honda
He should be able to help you with what you are asking. Just explain it to him and he'll be able to whip it up, no problemo.
--Topher919
Topher919 is offline
Old 05-25-2010, 10:56 AM   #10
Topher919's Avatar
Also found this for you:
02-07 Honda CB900F 919 Left Stock Exhaust OEM
--Topher919
Old 05-25-2010, 02:29 PM   #11
bwoso's Avatar
Thanks. I was looking for a used aftermarket can, something that didn't look bad from the side under the bike, but it doesn't look too promising. I have just been riding it how it is. I was thinking about painting it, or trying to use the heat shield from the right side somehow. I was also thinking about following the dirt bike bars with a can from a honda 450r or something. I have time to play with it. . . and I am also supposed to give Mark a call over at Black Dragon, I have an email from him with his number in it. I am not looking to spend a lot of money since I am not sure if I am going to like the looks or just change it again.
bwoso is offline
