curiousmike, I think that there is.
nd4spdbh, When I put it on my 919 it was under-sprung. I am 185. I would not venture to say if it would work out of the box for your weight. I know when I went up 50 lbs on the spring on my shock on the RC51 I had it re shimmed.
Just to clear things up. To set up the shock for a different spring rate and to adjust the compression and rebound all that is usually necessary is to re shim the valve, not re-valve. Valves are expensive, shims are not.
