I'll try to do a search for dimensions and angles; or if someone wants to chime in who has 'em it'd be appreciated. I just sent a PM to Ferris to see if he wants to part with the ones he just took off some from his 9er (scavenger I know).
I just mounted my windscreen about a week ago.
If you can wait a few days I can probably help you out with measurements & drawrings.
Pretty busy right now.
EDIT: I might add that I had to do a little bit of carving with a die grinder to make my brackets fit around the headlight bucket brackets. Without doing so, the holes in the mounting brackets wouldn't have mated up to the holes in the windscreen.
A tracing would be the best but as long as the drawing has the measurement, it would work. I think any format would do. The water-jet place can figure it out.
PM sent omaha.
Right on Omaha! And if I understand correctly from previous posts, these brackets will also fit the XB9S and XB12s flyscreen (for the dominator headlights) along with the M2 which is shaped for the stock headlight.
could be... I'll dig up the part numbers & post 'em in case others are curious.
Thanks for the link! I might just pull the trigger on those, but I'll give it a week and see if I can get one from Rickard. I'm positive the XB9/12 windscreens will fit those.
Sounds good, I'll just go on and do that. Now for the mounting screws...
EBAY.....Their called well nuts, and you can get them in all kinds of colors and styles, just search for wellnut....that is if you don't have anyplace local
ALL PARTS HAVE ARRIVED....let the wrenching begin!!!
My 9'er had a low side slide.....She's down but not out......and about to rise from the ashes!
Currently:
2004 Honda 919 Silver
599 Headlight
Buell M2 shield
Givi Crash bars
Dynojet PCIII
Akrapovic exhaust - GSXR shorty CF
Seat with gel insert and re-shape
Custom LED Rear lights w/ vizi-tech flasher
Competition Works Fender Eliminator
Front 3-way LED Turn Signals flushmount
6-Spoke wheel conversion ( 900rr / F3 )
Michelin Pilot Road 3 - New @ 19940 8/10/11
Dyna Beads for tire balancing
17t / 44t Sprockets
Piaa horns 400 & 500 hertz
Ohlins rear shock from an F3, Re-Valved/Sprung
F4i Forks, custom sprung/sealed
ASV levers - Black W/Red Adj.
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Custom one-off Bars W/Heat
RC51 front brakes w/Bremzen pads-10 button rotors
Buell Ulysses Foot Peg conversion
etc, etc,
