Old 11-29-2008, 08:24 PM   #1
No mo' 919
Trackday Recognition Veteran
Wheel bearings
Just a reminder for everyone: check and lube the bearings during the off season.
This is a new oem bearing
This is after HBR is done with it
HBR you da man
Sokali is offline   Reply With Quote
Old 12-03-2008, 09:28 PM   #2
Location: Hampton Roads, now I need a potato gun to hit another country with a rock.
I recognize those. Thanks for posting those up. Never had the chance to get around to doing that. Which reminds me I have to get in to do my front bearings soon.
Xbox Live: BDong625 / www.myspace.com/darkace625
darkace625 is offline   Reply With Quote
Old 12-03-2008, 09:32 PM   #3
No mo' 919
Let me know if you find a good deal on a set, besides oem.
Old 12-03-2008, 09:34 PM   #4
I ordered them all in a set from service honda.
Old 12-03-2008, 09:41 PM   #5
No mo' 919
How much for 2 bearings and 2 seals for the front?
I got the Allballs bearing kit for the rear. It was less than half the cost of oem.
They don't make a kit for the front, so I was thinking of heading down to LA bearings to see if they could match the fronts.
I need 2 front sets and 1 rear set.
Old 12-03-2008, 09:45 PM   #6
I can't access service honda while at work, but I will check first thing in the morning and let you know.
Old 12-03-2008, 11:15 PM   #7
Mike:
Try Midpoint bearing in Ontario
1155 W. Brooks Street
Suite 100
Ontario, CA 91762
(909) 391-1466
www.midpointbearing.com
Just South of the intersection of Holt and Mountain avenues
Their prices are always very competitive, and if they don't have a bearing in stock on average it takes only a day to get them.
robtharalson is offline   Reply With Quote
Old 12-04-2008, 04:09 AM   #8
Sokali.. Great post.... Which brand of grease are you using??...
Thanks Sokali
CB900F2 is offline   Reply With Quote
Old 12-04-2008, 04:46 AM   #9
Yea, his hands are way to clean, I dont think he got enough in there. I usually end up with my hands totally covered with goo before I'm convinced I got enought in there, LOL
CB900F2, just Use standard wheel bearing grease available at any autoparts store
justintyme73 is offline   Reply With Quote
Old 12-04-2008, 05:14 AM   #10
No mo' 919
Thanks Rob.
That's actually HBR's hands. Not sure about type of grease.
The point is that the factory does not pack the bearings properly.
It's worth a look during the offseason (?).
Old 12-04-2008, 10:11 AM   #11
Thanks Sokali
That would be Maxima WaterProof grease. It's a premium lithium complex NLGI #2 grade grease with a tackifier so it stays where it belongs. It's good stuff.
Professional
hasbeenracer is offline   Reply With Quote
Old 12-04-2008, 10:29 AM   #12
Thanks hasbeenracer
Old 06-13-2009, 05:30 AM   #13
Not too swift
Spec7's Avatar
So uhh whats the earliest anyone's heard of the rear bearings going bad? Less than 10,000 on the original bearings(yes I know I need to ride more) and the brake side rear bearing was toast. The grease was dried up and the dust seal had rust in it. Heading out to line the chain up now after installing an all balls kit.
2003 Honda 919, Carbon Sato's, PCIII-USB planned asphalt gray
2007 Majestic Blue NISMO KC, 4x4, 6-speed, Gibson catback, Clarion DUZ385SAT
2007 Trek EX8-Custom parts build by me for me
1992 Nissan 240sx- SR20DET swap, HKS intake, exhaust, and SSQV, VLSD, S14 Silvia JDM seats(super comfy), Exedy clutch
Spec7 is offline   Reply With Quote
Old 06-13-2009, 09:35 AM   #14
It seems to be a roll of the dice on whether or not the OEM bearings will have a sufficient amount of grease in them. When we popped the seals off of Darkace's brand new Honda OEM bearings to check, some were just barely addiquite while others had only one small dab of grease on just one side of the bearing...NOT GOOD!
I got into the habit of always checking all lubrication points on any new bike when I was a kid and am happy to say I have never had a bearing failure in over 35 years of riding and racing. Sokali's All-Balls kit wasn't to bad, but we repacked them anyways for good measure. Do a search and you will find a thread on how to get the covers off without damaging them. Best of luck to you.
Professional
« Gauge Q | big issue »
