Old 01-15-2012, 05:35 PM   #1
valve check
I have a 02 919. If all goes well i will be doing a long trip this spring, approx 5-6000 kms round trip depending on the final route.
the bike just rolled over 16,000 miles. I believe this is the recomended valve check. Is there generally any valves out of spec? I always do my own work, but it seams like quite the job. Not sure how the bike was driving in the past, i believe the old owner did alot for long trips.
Dose the site still have the shims kicking around?
Current Bikes: 2002 919, 2001 RM125
Past Bikes: 2005 DRZ400SM, 2000 CBR600F4, 1983 Virago 500, 1999 XR100, Z50
benr is offline   Reply With Quote
Old 01-15-2012, 07:09 PM   #2
Hastatus Prior
It's really not that bad of a project to tackle. I believe its a rare occasion for the 9er to have a valve out of spec at 16k, but I could be wrong. None of mine were out of spec at 18k and I raped my bike pretty hard between 9k and 18k, so thats the only thing I can for sure tell you. My suggestion is dive in, if you need a shim or two hit up a local mechanic and see if they won't swap them out for you. Last I heard the kit was slim pickins at best.
