Truck-Lite LED Headlight installation - Wrist Twisters
 1Likes
  • 1 Post By carotman
post #1 of 14 Old 04-08-2015, 06:31 AM Thread Starter
carotman's Avatar
After reading @marylandmike 's GE LED Headlight install-review, I decided I wanted to do try this
The headlight I used is very similar to the GE unit but is sold by Truck-Lite. The back portion is black instead of gray and the LED holder in the front is also black.
Truck-Lite - Catalog Product : 7'' Round LED Headlamp, Complex Reflector Optics Design
I decided to try a different route after reading that the the standard H6024 light will not fit the OEM 919 mounting hardware. Instead of modifying the headlight, I decided to try another trim ring from an older Honda. I wanted to be able to replace the headlight quickly in case the LED unit failed.
4into1 had exactly what I needed.
7" Chrome Headlight Rim / Retainer Assembly - Honda CB450 CB500 CB550 CB750K
The trim ring fits the 919 bucket size wise, but uses different mounting locations. The 919 ring has a tab on top while the new ring uses a bolt. The side bolts locations on the new ring are a bit more to the front and higher.
I used a Dremel tool to cut off the tab mounting point on the 919 bucket. This allowed the new ring to sit flush inside the bucket. I then drilled a mounting hole on the top of the bucket to accommodate the new ring.
carotman is offline
post #2 of 14 Old 04-08-2015, 06:36 AM Thread Starter
carotman's Avatar
To secure the trim ring on the headlight bucket, I bought another bolt and spacer from Honda. This allows the ring to fit securely to the bucket without crushing the plastic.
I then slotted the side bolts with the same drill bit I used for the top. Once this is done, the trim ring bolts perfectly to the 919 bucket.
You can now install any 7" round headlight in your 919 bucket.
CB 919 likes this.
carotman is offline
post #3 of 14 Old 04-08-2015, 08:31 AM
Nice work carotman! That upper tab that you cut off. Kept breaking off on mine anyway, so I just left it off. Nice clean install.
marylandmike is online now
post #4 of 14 Old 04-08-2015, 12:31 PM
Looks great! Must be a big improvement.
How much is that light? I may be blind but could not see a price on the link that you provided.
2005 Honda CB919F
2003 Honda CBR954RR (sold)
1990's Suzuki TS200 (sold)
1987 Kawasaki Ninja 750R (sold)
1984 Kawasaki GPz 550 (sold)
Dirt Bikes
op_man1 is offline
post #5 of 14 Old 04-08-2015, 04:18 PM
Nice... guess i have another project to do.
6camaro9 is offline
post #6 of 14 Old 04-08-2015, 06:19 PM
dazed and confused
EscapedLabRat's Avatar
Definitely prefer this over modifying the headlight itself; I'll have to try this once I can finally pick one of these up.
EscapedLabRat is offline
post #7 of 14 Old 04-08-2015, 06:34 PM Thread Starter
carotman's Avatar
You can get this in almost any auto parts store. I got mine from a friend that works in a truck parts supply. It was a gift so I don't know how much it costs locally.
You can get it on Amazon for a decent price though.
http://www.amazon.com/Truck-Lite-272.../dp/B007K8AA7I
carotman is offline
post #8 of 14 Old 04-08-2015, 06:46 PM
That's a really decent price. Post a review of the light if you haven't already!
Cheers
2005 Honda CB919F
Dirt Bikes
op_man1 is offline
post #9 of 14 Old 04-08-2015, 07:06 PM Thread Starter
carotman's Avatar
Too cold to ride right now and it's even snowing...
I should be able to test the light next week.
carotman is offline
post #10 of 14 Old 04-08-2015, 07:14 PM
I bet you will be pleasantly surprised. I know I was with the GE light which is pretty much the same, especially if you are going from stock.
post #11 of 14 Old 04-08-2015, 08:29 PM
Yeah, snowing here too. Nice forecast for the weekend, though.
If I get the $s, this is a definite mod for me in the near future.
2005 Honda CB919F
Dirt Bikes
op_man1 is offline
post #12 of 14 Old 04-09-2015, 07:11 AM
Gran Tirono
Asraiil's Avatar
Yeah, I installed the truck-lite on my Monster, the difference is pretty damn fantastic.
I do have one small issue with it, and that's the beam is so focused that when I lean into a turn, the beam dips out of my sight line, which at first was a little disconcerting. It might be due to the headlight angle (Maybe I have it pointed down too much or something), but I noticed that when I had it aimed higher I would get a lot more people flashing me with their lights because they thought my brights were on. Once I lowered it a little the flashing from cars stopped.
______________
'07 Ducati Monster S4RS
'06 Honda 919 (sold)
'95 Honda Rebel 250 (sold)
Asraiil is offline
post #13 of 14 Old 05-14-2017, 11:20 AM
So I followed your steps with a generic headlamp (don't have truck-lite/jw speaker money).
Did pretty well, the Emgo trim ring took some figuring out to attach it to the light, but in the end got it together. Those square nuts were a total pita to stay when attaching the bowl to the trim ring!
I dremeled away those clips, took apart the headlight and ring to use the ring and mark the top hole, drilled the sides up a bit, which sucked a bit, I gouged up one side a bit, and the light looks like it is rotated about 3 off centre
I really do like the look of it. I didn't have anything to solder/hook up the halo yet, but will probably get that on next weekend.
steev is offline
post #14 of 14 Old 05-19-2017, 08:50 AM Thread Starter
carotman's Avatar
Glad my instructions helped.
That light looks awesome.
carotman is offline
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
