Old 03-22-2009, 08:02 AM   #1
LIVE FOR THE PROCESS
Nesty's Avatar
Rust on steering stem
How do I handle this rust on the steering stem (and some spotting the forks)? Is it just naval jelly and clear-coat as a preventative?
Thank you in advance for your time,
Jon
Nesty is offline   Reply With Quote
Old 03-22-2009, 08:17 AM   #2
That's pretty ugly. Florida does bad things to bikes.
I'd clean that up and powder coat it. A cheap way would be to clean it up and paint it.
Old 03-22-2009, 10:05 AM   #3
oldguard60's Avatar
My 05 is starting to look like that, but not as bad...very light. I just spray with wd40 and wipe off the excess to keep it under control.Not sure if I can use a wire brush then paint it? Afraid about over spray on the other parts...
oldguard60 is offline   Reply With Quote
Old 03-22-2009, 12:17 PM   #4
Not Banned
Tk919's Avatar
I used a dremil with a wire brush attachment to buzz off the rust then taped off the forks with blue painters tape , I used a lacquer spray paint and just sprayed the paint into its own lid , then brushed it on with a fine model paint brush , the parts is rough enough that you don't see any brush strokes and it looked a heck of alot better than it did ...
Tk919 is offline   Reply With Quote
Old 03-22-2009, 12:26 PM   #5
Redonkulous
semi_gray's Avatar
I spent a couple of hours yesterday removing layers of rust that had formed on my draw-tite front mount hitch mounted to my '00 Z71.
I'd used "rust treatment" in the Navy and since then with pretty good results. Yesterday, I was using a can of brush on Permatex that I had in the garage.
Google turned up this about aerosol Permatex rust treatment. Might be worth having a look:
http://www.webbikeworld.com/t2/rust-treatment/
semi_gray is offline   Reply With Quote
Old 03-22-2009, 02:36 PM   #6
Nesty's Avatar
Seems like a dremil would get A LOT of use since it's mentioned 834,765,912 times on this site. Anything special I need to know now that I am going to go buy one?
Old 03-22-2009, 03:17 PM   #7
Not Banned
Tk919's Avatar
the cheep imitations work just as good as the name brand ones that is all ....
Old 03-22-2009, 03:49 PM   #8
Nesty's Avatar
Just curious, did you paint with a color (if so, which one) or just a clear coat?
Old 03-22-2009, 04:16 PM   #9
Not Banned
Tk919's Avatar
I used black .... the removal of the rust will discolor the silver color . I guess you could find a dull silver to match it ...
Old 03-22-2009, 04:41 PM   #10
Don't insert it into any body orifices is a really good tip.
Old 03-22-2009, 05:08 PM   #11
The rust problem is alive a nd well here in New England.
FYI: This surface rust problem has been around since the early days of the Hornet.
Mike's Bikes
Old 04-03-2009, 07:51 PM   #12
boogerface
mikochu's Avatar
He knows from experience...Trust me, I've seen him walk.
Michael Reyes
mikochu is offline   Reply With Quote
Old 04-04-2009, 04:27 PM   #13
CB900
rockdog32's Avatar
My 9'er was bought new in October '08, and the rust on the stem started 1 month later. I'm in country Queensland, nowhere near the beach. The bike has 14,000 kays on it now and I've kept it the same with WD-40.
I wonder if I can pull it on the dealer as a warranty issue? I mean, gee 5 months old and rust already!
rockdog32 is offline   Reply With Quote
Old 05-29-2009, 01:00 PM   #14
Guzzi Man
Honda beancounters strike again!
mikestib1 is offline   Reply With Quote
