Old 05-29-2009, 06:16 AM   #1
Slow.
theben's Avatar
Pop, sputter...F.I. issues?
So I am pulling away from a stoplight this morning under, I'd say, moderate acceleration, shift into third and there is a pop, followed by a lack in power, then things pick back up as per normal. My Fuel Injection light stayed on for a few seconds...has anyone had this experience? What is the likely cause?
theben is offline   Reply With Quote
Old 05-29-2009, 06:25 AM   #2
#1 question: What have you done to the bike recently? Maintenance, mods, tinkering, and the list goes on and on.
Mike's Bikes
Old 05-29-2009, 06:27 AM   #3
Slow.
theben's Avatar
Oil changed recently.
New chain and sprocket 100 miles ago. (Obviously unrelated).
Engine and exhaust is totally stock 'cept for a bafflectomy done by the previous owner.
It's a 2003 919 with approx. 12,800 miles, by the way.
Old 05-29-2009, 06:45 AM   #4
Have been riding in the rain lately? Might just be a loose ECM connector.
Mike's Bikes
Old 05-29-2009, 06:54 AM   #5
Slow.
theben's Avatar
I haven't been in the rain recently, but I have ridden the bike in all sorts of weather. The ECT is connected properly...
Any other thoughts? Or should I run the diagnostic.
Old 05-29-2009, 06:57 AM   #6
Signifer
scgstuff's Avatar
Donation Extraordinary Ride
Did you use the NOS octane booster energy enhancer? If not, give that a try....
(I was kidding, please don't try that.....)
Did you use a different type of gas than usual, or notice the fueling truck refilling while you were there? I heard that water and debris tends to get stirred up when the refueling truck is refilling the storage tanks at the stations.
Shawn
2004 Triumph Speed Triple SE (Speedy - Street Bike)
2002 Suzuki GSX-R600 (Shamu - Track Bike)
scgstuff is offline   Reply With Quote
Old 05-29-2009, 06:59 AM   #7
If the FI light is not ON, diagnostic won't tell you anything. How do you know the ECM connector is making a complete contact all the time? Did you unplug it then reconnect it checking for trace amounts of corrosion?
Mike's Bikes
Old 05-29-2009, 11:54 AM   #8
Slow.
theben's Avatar
Naw, fuel from the same two or three stations I use...
I guess I don't know if it is connected completely, but it isn't/wasn't backed out. This is the higher and smaller of the two plugs visible under the right side of the tank, right?
I guess I'll run the self-diagnostic tests on pages 5-6 thru 5-8 of the Owner's Manual to see if that tells me anything.
I rode to and from lunch and nothing happened. I ran it pretty hard through the gear, softer, varied the amount of throttle...nothing...
Thanks, guys, for working with me on this...I just bout some SW Motech side racks and Pelican case to do a little light touring...now this...
Old 05-29-2009, 07:29 PM   #9
Veteran Donation
Just for kicks clean this ground
http://wristtwisters.com/attachments...ing-small-.jpg
Mine was wierd for a bit this was the gemlin. 10mm and some sanding no worries.
tvetree is offline   Reply With Quote
Old 05-29-2009, 07:56 PM   #10
Heavy Metal
ratdog's Avatar
check your battery terminal connections
if one is a little loose and you hit something, it can cause the problem you describe, though i would've expected it to show up a couple times, not just the once
ratdog is offline   Reply With Quote
Old 05-30-2009, 11:21 AM   #11
Slow.
theben's Avatar
TVETREE and RATDOG,
Thanks. I'll do both of those and report back this week. I appreciate the suggestions.
On another note, I just installed the previously mentioned Motech racks and two Pelican 1520 cases...awesome.
