Old 12-06-2011, 06:19 PM   #1
TheBeeDeeGee's Avatar
Headlight brightens when revved, rectifer going bad?
Noticed this today when I got home, it's only very slight, but isn't this indicative of a battery on it's last leg? I also read something somewhere about the rectifier is about to go when this starts happening.
-2002 919 (fastest matte black)
TheBeeDeeGee is online now   Reply With Quote
Old 12-06-2011, 06:24 PM   #2
I'll add one to the mix, when I sound my Stebel, my headlight dims slightly. I'm guessing battery.
Old 12-06-2011, 06:51 PM   #3
Motorcycles (at least most current ones) have a basic problem when it comes to the charging system -- the generator is mounted on the end of the crankshaft, and at lower than ~2,200 RPM the surface speed of the rotor is insufficient to generate enough power to keep the system going, depending on the battery to make up the difference. That is referred to as the "break even point", and is the lowest RPM at which the system will continuously operate. Above that point the nominal voltage should be 13.8 volts or slightly higher, and below it the battery has to take up the slack but since the normal battery voltage under these conditions is about 12.8 volts or a bit less the headlight will noticably dim.
From your description I'd say it's normal and not worth worrying about.
robtharalson is offline   Reply With Quote
Old 12-06-2011, 07:01 PM   #4
ariannasdaddy's Avatar
Rob, is there anything you don't know?
Arte et Marte
ariannasdaddy is online now   Reply With Quote
Old 12-06-2011, 07:25 PM   #5
Hmmm ... I don't know.
Old 12-06-2011, 08:44 PM   #6
wait rob, you saying you dont know what you dont know?
Old 12-06-2011, 08:51 PM   #7
right answer... a person who says they know everything is vastly uneducated.
That stated... rob is a WEALTH of knowledge and probably knows more than most.
OP what ur describing sounds fine.... the 919 motor is easy to turn over... so when you start noticing that it cranks slower than normal... start lookin for a bat.
Old 12-06-2011, 09:04 PM   #8
Commuderator Munity
I was going to add that at idle, my Steibel horn also dims the light (noticed it when I tested it in the garage; also noted that I should not have tested it in the garage *ouch*).
Don't notice it at higher RPM's, but then again I don't tend to rev my bike in the gayrage and toot my own horn.
2006 Honda VTX 1300C (traded)
Old 12-06-2011, 10:20 PM   #9
CB900
rockdog32's Avatar
Wow, whats happening to WT, two people here have gayrage!
Bike sounds fine dude btw....
rockdog32 is offline   Reply With Quote
Old 12-06-2011, 10:42 PM   #10
sounds a lot like bobby!
Old 12-07-2011, 04:30 AM   #11
Shaughnessy's Avatar
It is actually a good way of eliminating the need for a voltage gauge on the bike. If the light brightens slightly when you rev, that means the charging system is working. If it doesn't, don't go far!
Shaughnessy is offline   Reply With Quote
Old 12-07-2011, 04:36 AM   #12
This is why I love this site, thanks dudes
Old 12-07-2011, 08:49 AM   #13
There are four categories of things "you dont know", and some are more dangerous than others...
1) There is the stuff you know that you don't know...Harmless. you cn always find out.
2) There is the stuff you don't know that you don't know...generally innocuous, but a little bit more dangerous.
3) Then there is the stuff that you think that you DO know, but don't. This can be deadly, and will sneak up on you at the very worst of times...this is the finger of Murphy in action.
Rob has wisdom!
Old 12-07-2011, 09:10 AM   #14
Rob has wisdom!
you forgot the 4th one dec:
4) things you know you don't know and have no intention of ever knowing for to know is to become deeply scarred. an example is knowing how your parents get it on
Old 12-07-2011, 09:17 AM   #15
Hmm...Did I? Thats curious...
Old 12-07-2011, 09:48 AM   #16
A quick take on this:
Facts are information.
Knowledge is the ability to apply information to specific situations, and to know what information is pertinent.
Experience is the end result of the application of information tempered and ordered by knowledge.
Wisdom is the experience that gives you the knowledge that you will never have all the information you need to be absolutely certain of anything.
Consequently, if you talk with someone who is absolutely certain of something, they may be informed, but they are probably not knowledgeable, almost certainly not experienced, and definitely not wise. This is known as wizzdumb, and is the normal human condition.
I think.
Old 12-07-2011, 12:19 PM   #17
Rich Jura's Avatar
I think.
I like that a lot, always tell the kids here at school never trust anyone who claims to know everything.
Rich
Rich Jura is offline   Reply With Quote
Old 12-07-2011, 01:06 PM   #18
Man, I had to read that about 4 times just to understand what you are saying!!
Dumb it the f&%k down please! JK! I really absorb your wisdom as much as I can.
Arte et Marte
Old 12-07-2011, 01:53 PM   #19
Focus, Grasshopper. Wisdom will come if you let it.
Incidentally, Arianna is my gradddaughter. I assume it's a different Arianna. Unless, of course, you or I don't have all the pertinent information necessary to be knowledgeable on the subject.
Old 12-07-2011, 02:26 PM   #20
[translation] Who's Yo Daddy? [/translation]
marylandmike is offline   Reply With Quote
Old 12-07-2011, 03:19 PM   #21
wise words rob wise words! i love to practice Socratic ignorance, you learn much more that way.
Old 12-07-2011, 03:59 PM   #22
Well..... since my father and I are clearly cut from the same cloth.... I'd say Arianna is a simple coincidence....
Though, Dad, I would love a set of tharbars for christmas.....
Arte et Marte
Old 12-08-2011, 02:09 AM   #23
What about the stuff I never wanted to know but someone told me - I now need to know how to forget that stuff .......
Like 'felching' - even typing the word brings a small amount of vomit up the back of my throat.
Old 12-08-2011, 05:47 AM   #24
Definitely a great start to my morning.... reading the word felching and almost dry heaving
Old 12-08-2011, 06:25 AM   #25
oh god.... thanks a lot!
Old 12-08-2011, 03:18 PM   #26
Commuderator Munity
PV, even I know there are certain things you just DO NOT google....
Old 12-08-2011, 03:57 PM   #27
Speaking of the headlight, is there a bulb you can by to make it a little better? Can't do the 599 headlight upgrade right now, and riding at night has been sketchy
