01-04-2012, 04:10 PM
#1
Gas cap sticking
Went to fill up and took 25 min to force it open. it locks and unlocks but is sticking. I want to use some lube but worried it might contaminate the gas... thoughts?
01-04-2012, 04:18 PM
#2
undo the 6 allen bolts just enough so that you can slide the gas cap assembly around, and find the spot that it opens in the easiest. i want to say the gas cap has to little latches on the sides that move in and out... so centering the gas cap assembly should make it the easiest.
#3
I had issues with the key not wanting to come out. Finally replaced it with one of those ebay screw-on specials for $35.
01-04-2012, 04:20 PM
#4
Is the tank developing a vacuum situation or is the cap sticking?
01-04-2012, 04:55 PM
#5
blur
just do the 3 that hold it on. 12,4 and 8 o'clock
01-04-2012, 05:32 PM
#6
I was just outside and took it off, using the 3 bolts that Drew mentioned and yes there is 2 tabs... I cant rotate it?!?! its a fixed mounting position.. so i put it back on. yes its sticking ,,, or one hell of a vac. lol.
do you think should use a bit of chain lube on the springs?
01-04-2012, 06:31 PM
#7
919>food>beer
use graphite... and its been found that washers under the cap in the front bolts will help it... search around I know it has been discussed many years ago
01-04-2012, 06:32 PM
#8
919>food>beer
Cure for sticky gas cap
actually there you go...
01-04-2012, 07:21 PM
#9
Thanks I will try it
01-12-2012, 08:54 AM
#10
I have a sticky gas cap too.. Wow, a 2-years old thread did helped me. A simple and genius solution...
You wouldn't know what help you gonna get from a good bunch of friends in WT....
Thank you guys....
-RJ-
01-12-2012, 09:57 AM
#11
Family Dog
Mine was sticky too. So after reading this thread I checked into it. I was able to fix mine by just loosening the three mount bolts, shutting the cap, then torque the three mount bolts. Now it wrks smooth.  thanks for the heads up guys!
2002 Honda 919 in Fast Black
2006 Honda 599 sold
1999 Honda CR 250
| Thread Tools |
| Display Modes |
Linear Mode
