Originally Posted by kctigerfan
Okay, I'm not only new here, but I'm also new to motorcycles...so this may seem like a dumb question...which I'm fine with as long as I get an answer from someone.
Here's my question: How do I adjust my friction zone on the clutch? I'd like it to engage closer to the grip and I'd like the overall friction zone to be increased.
Here's a picture showing where my friction zone starts and where I want it to start.
The blue line indicates the clutch all the way in.
The green line shows where I want the friction zone to start.
The yellow line shows where my friction zone currently starts.
The red line shows my clutch all the way out.
Right now my friction zone is about .5" big. I'd like my friction zone to not only start at the green line shown above, but I'd also like my friction zone to be about twice as big.
So, how do I accomplish this? Should I try and make this change or should I just live with with how my clutch is currently set up? What are the advantages/disadvantages to either way?
Thanks.
The 919 has an old school clutch lever setup, the lever is miles away from the bar, just like the bikes of old. The lever shape is part of the problem, the other cause being the distance from the lever pivot point to the handlebar.
I started by using lots of cable slop.
I was not happy.
I got a CRG clutch lever and ran the lever in position 1
It was better, because I was able to then get rid of some of the cable slack I had added in.
I was not yet satisfied.
I then determined that a Honda F4i clutch lever bracket would match up to the 919 cable, use the same CRG lever, the F4i bracket having the pivot pin closer to the bar than the 919 design.
This is my current setup. (you lose the mirror mount but I'm running bar end CRGs so do not care about that.)
I still run the CRG at position 1, and it's not bad, not perfect, not as close in as ideal for me, but OK.
The next step would be to fish about for a compatible bracket, be it Honda or other Japanese sport bike, that I could graft on and still use the same cable. One that has the pivot point even closer to the bar. A 06/7 GSXR 600/750 may be a possibility based on eyeballing what is in our garage.
By the way, I bought a new clutch switch for the F4i bracket. The switch is common with the 919, but is a light duty plastic piece I figured could easily break if I tried to press or drift it out to reuse. So, I bought a new switch. The point being, you need an operational clutch switch, so if you try to use something off another bike, some jury rigging will likely be needed to be able to connect the Honda leads to the connectors on the switch of whatever lever assembly you are trying to utilize off another unrelated bike.
