Old 11-25-2011, 05:17 PM   #1
jscott's Avatar
CBR 900 Rear Wheel
It was a beautiful day, 60F and sunny, so I was getting some parts sorted for powder coating. I knocked the bearings out of a CBR 900 rear wheel and was met with this:
I can't find a picture of another wheel, rotor-side without the bearing in it, that looks like this. Checked a few part fiches, but they aren't detailed enough... Is this normal? The three protuberances appear much rougher cut than the center circle.
cat /dev/null > ~/.sig
jscott is offline   Reply With Quote
Old 11-25-2011, 05:38 PM   #2
The three "protuberances" are there to positively locate the spacer tube between the bearings, and will not contact it once the axle is in place. It's common in wheels that are made as light as possible and / or where frequent bearing maintenance is expected, such as when racing (the cutouts allow access to the outer race in the event of catastrophic failure).
robtharalson is offline   Reply With Quote
Old 11-25-2011, 07:47 PM   #3
919 aka Hornet 900
Mr T81's Avatar
Mine was like that too
Mr T81 is offline   Reply With Quote
