Bad wheel bearing picture - Wrist Twisters
post #1 of 30 Old 03-24-2012, 05:28 AM Thread Starter
Eric's Avatar
Hi guys,
I Have replaced my 2 rear wheel bearing , i had an issue with the right hand one( brake side) . I opened the bearing seal and found it pretty worn and the grease is just very bad . I think water went in it .
The picture with both bearing show the left hand side bearing who is in good shape and the right hand one is really bad.
Eric is offline
post #2 of 30 Old 03-24-2012, 05:35 AM
How many miles on your Hornet?
07919Dave is offline
post #3 of 30 Old 03-24-2012, 05:48 AM
Looks very familiar
My right side bearing at 37K miles
Something just didn't feel right
post #4 of 30 Old 03-24-2012, 06:00 AM Thread Starter
Eric's Avatar
mine had just 14000km
it is pretty soon for a bearing to be worn like that
Eric is offline
post #5 of 30 Old 03-24-2012, 06:00 AM
TEXAN
MF1VE's Avatar
Definitely looks like water damage - the rust inside the bearing looks much like the bearings I used to pull from Italian cars.
MF1VE is offline
post #6 of 30 Old 03-24-2012, 06:19 AM
Yeah that seems a bit to soon. 8700mi and a bearing goes out sounds like a defect. Replace with a high quality brand and ride on!
post #7 of 30 Old 03-24-2012, 06:41 AM Thread Starter
Eric's Avatar
I ve replaced them with all balls bearing they seem s good so far
Eric is offline
post #8 of 30 Old 03-24-2012, 07:13 AM
"Whose ABBA ZABBA?"
Looks very familiar
Classic, Mike. Just classic!!!!!
Extra gluten for me, please. And can you not skimp on my caffeine the next cup?
post #9 of 30 Old 03-24-2012, 08:56 AM
Amphibious's Avatar
out of curiosity, what is the consensus on the best wheel bearings to order?
Amphibious is offline
post #10 of 30 Old 03-24-2012, 09:10 AM
I think most people prefer All Balls
post #11 of 30 Old 03-24-2012, 11:32 AM
ya i dont roll that way.... i prefer all pink tacos.
haha, naw i have used all balls bearings before they are good stuff.
post #12 of 30 Old 03-24-2012, 12:33 PM
Chinese made, though - I'd rather avoid those in critical high speed bearings.
post #13 of 30 Old 03-24-2012, 12:49 PM
Anyone think they're better than OEM?
post #14 of 30 Old 03-24-2012, 12:50 PM
Stutz's Avatar
Stutz is offline
post #15 of 30 Old 03-24-2012, 01:12 PM
NWTB Non Stinky 919
jeffie7's Avatar
Mikes 919 only had bearing failure due to playing with my Gsx-r. . I kid I kid.
jeffie7 is offline
post #16 of 30 Old 03-24-2012, 01:38 PM
Man - just soak them in some Rotella - apparently that stuff is the jizz! (OK just joking).
Never ues one of those high pressure water blasters around your bike - they are the best way to get water where you don't want it.
post #17 of 30 Old 03-24-2012, 03:13 PM
no. OEM is the way to go. All All ball made in China. They are good bearings but quality control is nowhere near OEM as you can imagine with mass produced stuff in China. All Balls just buy bulk bearings and package them as ABB. Nothing special about All Balls except catchy name.
zaq123 is offline
post #18 of 30 Old 03-24-2012, 03:32 PM
with this rust damage, better question is how old is this bike and how was it stored from its birth to present day.
I have a feeling this bike spent a lot of time outside. Heat/cold: condensation and moisture did its job. On average, 0.002% water in the lubricant can reduce bearing life by 48%. Six percent water can reduce bearing life by 83% percent.
Sealed bearing will not prevent moisture/condensation. Sealed bearing designed only to keep grease from coming out.
zaq123 is offline
post #19 of 30 Old 03-24-2012, 06:00 PM
It's the best explanation so far
post #20 of 30 Old 03-24-2012, 07:35 PM
blur
drewvir's Avatar
if ya repack before they look like that they last alot longer
http://www.wristtwisters.com/f94/bad...tml#post302034
see post #20
drewvir is offline
post #21 of 30 Old 03-24-2012, 09:23 PM
For that matter, is there any way to convert to taper roller?
post #22 of 30 Old 03-25-2012, 03:56 AM
no no no no. Don't even think about it for wheel bearings. Are you crazy?
zaq123 is offline
post #23 of 30 Old 03-25-2012, 06:53 AM Thread Starter
Eric's Avatar
To answer your question ZAQ123, I bought the bike last summer ans i noticed the bearing sideplay 2 month later , I know that i the third owner. But for sure their was a lack of maintenance. Or maybe one of the previous owner ride the bike a lot in rain and with the heat of the brake maybee it didn't help for condensation. Or the bike was pressure-washed behind the disc brake to removed all the dirt and brake dust wich is not a good idea do to that.
Bearing seal seem perfectly installed and good.
Eric is offline
post #24 of 30 Old 03-25-2012, 07:44 AM
"Whose ABBA ZABBA?"
These guys are the tits.
The Timken Company - Bearings, Alloy Steel, Power Transmission, Engineered Surfaces, Lubrication, Seals, Motion Control Systems, Services
post #25 of 30 Old 03-25-2012, 10:33 AM
frankly's Avatar
Or perhaps somebody got carried away with a pressure washer? Probably more likely/common with an off-road bike/quad, but god only knows...
frankly is offline
post #26 of 30 Old 03-25-2012, 10:42 AM
I'm starting to think the pressure washer may have contributed to my bearing failure. There definitely wasn't that much grease in there. I used a pressure washer once or twice and I'm sure I hit that area.
Live n Learn
post #27 of 30 Old 03-25-2012, 10:53 AM
Only as crazy as 99+% of car manufacturers. Most cars use taper roller bearings for their wheel bearings.
post #28 of 30 Old 03-25-2012, 11:12 AM
Tapered bearings can't handle misalignment as we as ball bearing do. OEM DAC type bearings are good stuff. I'm running one in my Satos. Had to adjust PCIII to 248.6 degrees for TPS Flux vector drive though with this setup
zaq123 is offline
post #29 of 30 Old 03-25-2012, 12:31 PM
post #30 of 30 Old 03-25-2012, 03:45 PM
Simply put, the loads upon the bearings are such that tapered rollers are not needed.
Unlike a car.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
