Old 01-23-2012, 08:36 PM   #1
Any tips for removing the starter?
Starter is starting to go, need to clean it or rebuild it. Looking over the manual it seems like a lot of work just to get to the starter. I tried using just a standard 10mm wrench to get the two bolts holding the back of the starter, but it's too tight for me. Has anyone successfully bypassed the whole tank/air removal in removing the starter? I'm thinking a long 10mm wrench would do the trick, just seeing if you guys have had any luck using other various ways.
fritzwilliam is offline   Reply With Quote
Old 01-23-2012, 08:55 PM   #2
still jonesin
1st time I've heard of any starter problems, dose your bike have high mileage or been subjected to unusual service?
ideajones is offline   Reply With Quote
Old 01-23-2012, 09:16 PM   #3
Commuderator Munity
or are you sure you just don't have a weak battery?
2006 Honda VTX 1300C (traded)
Old 01-23-2012, 09:24 PM   #4
ya... KISS method.... first time i have ever heard of someone having starter issues on the 919.
Old 01-23-2012, 09:40 PM   #5
Hastatus Prior
I could very well be wrong, but warn valves could make it seem like the starter is weak (besides the battery, which has already been mentioned) When's the last time the valves had their checkup done?
Old 01-23-2012, 11:04 PM   #6
ya i think we need some more info on the bike like stated.
id be willing to bet its as simple as a battery though.
