Old 07-19-2007, 07:52 PM   #1
Vintage Honda
DR. J's Avatar
removing decals
I pulled the 'always wear a helmet and don't ride backwards sticker off the top of the tank of my niner. What do I use to get the stickum off?? Any thoughts. My fingernail won't even scratch it off. Thanks
Big vintage bike show at mid-Ohio at the end of the month. Anyone going to be there?
DR. J is offline   Reply With Quote
Old 07-19-2007, 08:07 PM   #2
I removed my stickers from my 919 tank, used a bit of bug and tar remover to get the sticky off the paint, then polished it with wax. Unfortunately the paint is faded a bit on my '02 asphalt tank so you can still see where the stickers had been. I went against the advice of the removed sticker and used a light polishing compound, then some black color wax, made it better but not perfect.
I'd be interested in the bike show at Mid-Ohio, got any details?
Old 07-19-2007, 08:13 PM   #3
3M General Purpose Adhesive Cleaner
Part No. 051135-08984
comes in a 1Qt metal rectangle-shaped can
white with a red front
I got mine from a place that specializes in auto paint & supplies.
omaha_919 is offline   Reply With Quote
Old 07-19-2007, 08:18 PM   #4
+1, that stuff works great on any adhesive.
Ridge is offline   Reply With Quote
Old 07-19-2007, 08:21 PM   #5
Try naptha. I use it all the time in my shop on guitars that the owner covered with stickers that say "f-u to the world" and now they are going to play at church so they want all that stuff gone. It will strip off any wax but won't hurt the paint. You can buy it at home depot. You can also use ronson lighter fluid--the kind you squirt into the bottom of a zippo--in a pinch, it's the same stuff. Wash your hands as the stuff soaks into your skin and it's hell on your nervous system.
hasbeenracer is offline   Reply With Quote
Old 07-19-2007, 08:21 PM   #6
I use GooGone on the remaining adhesive, and it's excellent.
Doesn't hurt the paint at all.
JohnnyLfromCT is offline   Reply With Quote
Old 07-19-2007, 08:27 PM   #7
Wookie
ragdoll's Avatar
+1
'02 RC-51
'10 Unicycle
ragdoll is offline   Reply With Quote
Old 07-19-2007, 08:50 PM   #8
More like Snoreway
cmelnick's Avatar
Donation Extraordinary Ride
Are the mattress-tag police banging down your door yet? Oh, they'll be there...they'll be there...
They're everywhere...watching...
- Stephen Hawking
cmelnick is offline   Reply With Quote
Old 07-19-2007, 09:26 PM   #9
Bikeless Rider
Patmicg's Avatar
+1
-Pat McG
Patmicg is offline   Reply With Quote
Old 07-20-2007, 02:35 AM   #10
Vintage Honda
DR. J's Avatar
Thanks for the help. Just nervous touching the paint.
Old 07-20-2007, 03:34 AM   #11
Ken
Community Admin
Ken's Avatar
Hair dryer + WD-40 = no more stickers
2009 Honda Goldwing
Ken is offline   Reply With Quote
Old 07-20-2007, 05:42 AM   #12
More like Snoreway
cmelnick's Avatar
I'm assuming hair dryer to loosen the gum, WD-40 to remove residue? Good idea!
- Stephen Hawking
Old 07-20-2007, 05:54 AM   #13
Heat the decal with the hair dryer. You would be surprised how easy it will come off. The heat also helps to keep the goo at a minimum.
Mike's Bikes
Old 07-20-2007, 05:58 AM   #14
Ken
Community Admin
Ken's Avatar
Exactly. And as Mike said, most will come off by just warming the adhesive. But stubborn ones may need a squirt of WD-40.
2009 Honda Goldwing
Old 07-20-2007, 06:03 AM   #15
wisco919's Avatar
+1 Naptha works excellent and is pretty cheap.
wisco919 is offline   Reply With Quote
Old 07-20-2007, 06:04 AM   #16
Me, thas who.
tpirman's Avatar
BOTM
I love Goof Off, I use it all the time for random things. (That sounds kind of gross). Anyway, I've used it on paint and doesn't seem to do any harm, but just in case, try it on a test area first.
tpirman is offline   Reply With Quote
Old 07-20-2007, 08:35 AM   #17
Quitting is for Quitters!
LittleNinja's Avatar
Goo Gone!!
-Mercedes- or you can call me YaYa
LittleNinja is offline   Reply With Quote
Old 07-20-2007, 08:43 AM   #18
SportyChick's Avatar
I will also vouch for Goo Gone!
SportyChick is offline   Reply With Quote
Old 04-11-2011, 01:26 PM   #19
Just adding 2c , i've removed the stickers off the rear cowl with a heat gun and the rest of the goo with Acetone , worked like a charm and no Acetone won't ruin the clear coat.
hangster is offline   Reply With Quote
Old 04-11-2011, 01:34 PM   #20
WD40 here too, works great.
Old 04-11-2011, 03:10 PM   #21
+1... WD40, good for 1001 motorcycle friendly household uses.
Old 04-11-2011, 03:33 PM   #22
Commuderator Munity
Use lighter fluid (Zippo, etc.). You won't even have to use a hair dryer, it just gums up and wipes off with a paper towel. Although I like the smell of WD40 as well as Zippo, so no downsides there, lol.
2006 Honda VTX 1300C (traded)
g00gl3it is online now   Reply With Quote
Old 04-11-2011, 03:35 PM   #23
Commuderator Munity
...but, Acetone is VERY bad for plastics. It's the main ingredient in ABS cement. It will literally re-melt the plastic until it dries.
Just ask my old roommate what happens when you set a dripping bottle of it on the top of the Playstation 2 .
Old 04-11-2011, 08:23 PM   #24
Well i had no issues with it at all , (no damage no problem ).. it is a paint thinner but evaporates so fast there is no problem using it..
Old 04-20-2011, 08:47 PM   #25
Even good old Windex will remove the stickum, used it on my Super Duke tank sticker with success.
Old 05-11-2011, 06:13 PM   #26
I understand this thread is VERY old, however, felt it necessary to add this...
I wouldn't have tried ANYTHING listed in this thread on my paint if I hadn't read that someone else had done it first...
To remove sticky stuff left behind from any sticker, ahem, Butter.
Butter, margarine, vegetable oil... On a paper towell. Try it. Seriously. And you never have to worry about margarine wrecking your paint.
Phoenix82 is offline   Reply With Quote
Old 05-12-2011, 03:50 PM   #27
Commuderator Munity
yeah, but then you have to use something else to get the fatty substance off.
Seriously, use Zippo lighter fluid. It actually DISSOLVES adhesives. squirt and wipe. And it won't affect any finishes.
Old 05-12-2011, 05:43 PM   #28
schrock86's Avatar
I've used this with great results, I may have to try the lighter fluid though.
http://shop.advanceautoparts.com/web...i_sku=99985928
schrock86 is offline   Reply With Quote
Old 05-17-2011, 03:42 PM   #29
Commuderator Munity
Buy 3M Adhesive Remover (12 oz.) 03618 at Advance Auto Parts
yeah, lighter fluid is cheaper, lol.
You know how I learned about it? While a bagger at Albertsons. My first job. This was back when STICKY labels were on all the shelves and yes, I was the little d*psh$t that got to remove them all. I have first hand knowledge of how well it works.
Old 05-17-2011, 03:57 PM   #30
Mookie Power
caferacer72's Avatar
All of the above will work. BUT DO NOT AND I REPEAT DO NOT !!!!! USE PAPER TOWELS ON YOUR PAINT IT WILL LEAVE SWIRL MARKS....... ESPECIALLY ON BLACK AND ALL OTHER DARK COLORS. USE A MICROFIBER CLOTH AND YOU WILL BE OK !!!!!!!!!!!!!!!!!!
caferacer72 is offline   Reply With Quote
Old 05-18-2011, 03:13 PM   #31
Commuderator Munity
more proof....Dissolve Sticky Residue with Lighter Fluid - Lifehacker
gotta love lifehacker.
Old 05-18-2011, 04:36 PM   #32
OSIRIS's Avatar
I still have that Playstation sitting in my cabinet! Laser stopped working on it so it hasn't been used in years... still has the round ring of the bottle on the top of the case....
..... basterd.... jk
2004 Honda Shadow Aero
OSIRIS is offline   Reply With Quote
Old 05-19-2011, 01:12 PM   #33
Commuderator Munity
That's BASTARD. Get it right.
