Old 11-28-2009, 10:28 AM   #1
BAD9one9's Avatar
please help...again
when i removed the stock cans to replace there are these clamps on the end of each of the Y pipe, they are wrapped fully around with no openings and are clamped down indented into the pipe, they dont slide, dont twist, and i need them gone so my new cans can slide down further, anyone ran into this? do i use a cutter and cut them, im scared of cutting the pipe. heres a pic. (its the rusty ring)
File Type: jpg 13332_353098915172_673820172_9991779_4678607_n.jpg (48.8 KB, 65 views)
BAD9one9 is offline   Reply With Quote
Old 11-28-2009, 12:38 PM   #2
Please put an arrow to exactly which piece you are talking about. Because (and my eyes aren't the best), I think you are actually talking about the exhaust gasket.
sike is offline   Reply With Quote
Old 11-28-2009, 12:53 PM   #3
MachMoto.com
Ripper's Avatar
I thought the Two Brothers was a single can? You should have received a new pipe to replace the Y-pipe and a dummy can for the left side that is storage only.
But to answer your question, NO. The stop on the Y-pipe does not come off and is to be used as a stop for how far the can slips on.
It seems to me that you have either the wrong system or a incomplete system.
Ripper is offline   Reply With Quote
Old 11-28-2009, 12:53 PM   #4
MachMoto.com
Ripper's Avatar
What is the part number of the system you bought?
Old 11-28-2009, 03:07 PM   #5
BAD9one9's Avatar
i bought the dual can system, so the Y stays there, however what ever the metal band was, i used a cutter to cut it, then used an air hammer with narrow tip on it to pop it off, hope its not a big deal. just finished the whole job, cant wait for the silicon sealent to dry so i can try it out. thanks for the help.
Old 11-28-2009, 06:02 PM   #6
Speed Lover
XRCajun's Avatar
Silicon sealer on the exhaust pipe?
XRCajun is offline   Reply With Quote
Old 11-28-2009, 08:31 PM   #7
myztical's Avatar
I put on the Yoshi slip ons and I didn't have to cut anything....
When you took off the stockers they should of came off from the ends of the y-pipe. Did you disassemble the cans from the midpipe? That clamp should loosen and then the midpipe along with the can should slip off with a little twisting. Then the new one slips on, and the rusty ring is as far as it can go.
I am not sure about the silicone sealant. I didn't use any and don't think Ive heard of anybody using it before.
"An armed society is a polite society. Manners are good when one may have to back up his acts with his life." ~Robert A. Heinlein
myztical is offline   Reply With Quote
Old 11-30-2009, 04:52 AM   #8
I'm pretty sure that metal band is there as a stop to keep your cans from sliding down the y pipe.
Old 11-30-2009, 05:52 AM   #9
and you are completely correct as to its function
Old 11-30-2009, 05:53 AM   #10
MachMoto.com
Ripper's Avatar
Call me crazy... but I still think you are missing parts, have the incorrect parts or the wrong system.
What is the part number?
Old 11-30-2009, 05:54 AM   #11
crazy!!!!! crazy!!!!!!!!!! burn him.... he's a witch...
Old 11-30-2009, 05:59 AM   #12
Vehicle Abuse Specialist
WheelieTime's Avatar
Next will be zip ties and duct tape.
WheelieTime is offline   Reply With Quote
Old 11-30-2009, 06:11 AM   #13
and yea he saw they were good and on the 6th day he created gorilla glue and he rested...
Old 11-30-2009, 11:03 AM   #14
BAD9one9's Avatar
here is the instructions from my exhaust http://www.twobros.com/Cust_Service/...004xD_Inst.pdf it came with high temp silicon sealer to use at each fitting and is included on the two bro's website instructions. i followed the directions and it turned out great, sure sounds good to me.
Old 11-30-2009, 12:56 PM   #15
Isn't that the gasket for the stock mufflers? I would think you could take it off if the two brothers system doesn't use it.
marylandmike is offline   Reply With Quote
Old 11-30-2009, 01:25 PM   #16
I don't know, but I know those 'stops' (or rings) are still on the Y-pipe and their looks to be some sort of metallic mesh gasket inside the slip on part of the stock exhaust.
EDIT: Here is a picture from LordDuckHunter's site showing detailed installation of Sato pipes AND the ring/stop in question.
Old 11-30-2009, 02:09 PM   #17
Yep you're right. I looked in the manual and there is that ring and a gasket. When I removed mine I guess I didn't look inside the muffler so I didn't see the real gasket.
Old 11-30-2009, 06:37 PM   #18
BAD9one9's Avatar
so is this a problem that i removed the ring? or should it be ok?
Old 11-30-2009, 06:54 PM   #19
CG
catonsvilleguy's Avatar
Should be O.K. But I think you'll want to install new ones if you decide to reinstall the stock cans.
catonsvilleguy is offline   Reply With Quote
Old 11-30-2009, 07:11 PM   #20
Self proclaimed idiot....
Border's Avatar
Hey, hey.. Hey there..
Gorilla glue is great a long as you spit on the matching part.
But on an exhaust system, I wouldn't count on it.
It would look something like a bad spray foam installation.
Border is offline   Reply With Quote
Old 11-30-2009, 07:13 PM   #21
yeah... its only in context if you read the quote i quoted about the duct tape n stuff....
Old 12-05-2009, 02:26 AM   #22
I installed a FMF silencer/spark arrestor on my SX 450 KTM dirt bike and I used the high temp silicone as well. Seems like all the dirt bike guys use it on 4 strokes.
RB
RBrider is offline   Reply With Quote
