Old 10-11-2011, 12:05 AM   #1
Oxford Heated Grip Help!
HI Guys,
Just wondering how you tap power for heated grips. I connected white(+) cable to my low beam and (-) to battery. Head lights and signal lights will deem every other second when heated grip is on low setting. I don't think this is good for the bike's electrical so I currently run it off battery but I forget to turn it off a few times and leave myself a dead battery sometimes. Any better idea is appreciated.
bladerdavid is offline   Reply With Quote
Old 10-11-2011, 01:51 AM   #2
I installed a secondary fuse block that is only powered when the bike is running. I used the universal one:
EC - Power Plate
Old 10-11-2011, 05:57 PM   #3
Oxford Heated Grip
Hi RMB,
Thank you for the quick reply. I understand the concept now but for the EC plate, if I attach the red to main, where do I plug the gound to to make it shut off when the engine is off?
David
Old 10-12-2011, 01:49 AM   #4
Originally Posted by bladerdavid View Post
Hi RMB,
David
I used EC's master ground block:
EC - Master Ground Block
Old 10-12-2011, 08:46 PM   #5
Heated Grip
Thank you RMB. Let me order the parts in now. Appreciate your help!!!
David
Old 10-13-2011, 01:56 AM   #6
You're welcome.
