Old 04-18-2010, 05:52 PM   #1
919lover
Wolverine's Avatar
Headlight Conversion
I'm looking to do the headlight conversion, can someone tell me which dual headlight set will work for the 9er and also will I be able to continue to use me f-16 wind screen.
Wolverine is offline   Reply With Quote
Old 06-18-2010, 04:54 PM   #2
Tx919's Avatar
Try checking out Aztec8.com for a dual headlight conversion.
Tx919 is offline   Reply With Quote
Old 06-18-2010, 05:24 PM   #3
These bolt right on and no extra wiring necessary. (Relay installation is recommended though).
Dominator Streetfighter Dual or Single Headlight for Motorcycles
However, if I've known about the Aztec8 website, I'd definitely go with the 5 3/4" duals instead of the 4". I think it looks better and will probably have a better dispersion.
andrewebay1 is online now   Reply With Quote
Old 06-18-2010, 05:50 PM   #4
However the 5 3/4" (from Aztec) will need the $88 bracket kit. I can't say for the 4", but the ones from FlynCycle bolts right onto the stock headlight bracket.
Old 06-18-2010, 06:03 PM   #5
someone in china needs to make knockoffs of the dominators... i like em... but the price needs to be chinafied!
Old 06-18-2010, 11:02 PM   #6
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
I got a set of dual lynx headlights from england that use the stock headlight mount ... think these would work with your screen?
yostevo052 is offline   Reply With Quote
Old 06-19-2010, 05:48 AM   #7
919Mofo's Avatar
How do you guys hide all of the plugs and wiring that are in the original headlight bucket when you swap to a dual setup?
919Mofo is offline   Reply With Quote
Old 06-19-2010, 01:04 PM   #8
You can pull the main cable back into the engine area by loosening the clamp on the right side. It doesn't pull all loose cables back, but it makes it easier to manage under the dominators.
Old 06-20-2010, 04:49 PM   #9
Gets censored
Products
Personally I think the bigger lights look right on the 9er. take a look your screen it bolts to your handle bars, right?
Old 08-19-2010, 01:26 AM   #10
Carp Killer
Wallybanger's Avatar
I've been thinking about goin to the 599 headlight because the 919 light sucks pretty bad... especially on these hilly/windy BC roads!
Wallybanger is offline   Reply With Quote
Old 08-19-2010, 04:10 PM   #11
919 aka Hornet 900
Mr T81's Avatar
http://www.northeaststreetfighters.c...-Gas-Mask.html
I wonder what this would look like on a 919??
Mr T81 is offline   Reply With Quote
Old 08-19-2010, 05:38 PM   #12
$369 for a gas mask??? hahahaha
Old 08-19-2010, 05:54 PM   #13
Interesting but fugly....
rmb is online now   Reply With Quote
Old 08-19-2010, 06:02 PM   #14
mambomonster's Avatar
There are some drop in solutions available for a 7 inch light but the HID and LED variety are expensive - I've been checking. They range from $300-500 which is a bit expensive for a headlight, but then again there is some value in the ones that offer an H4 connector as the installation is simpler.
mambomonster is offline   Reply With Quote
Old 08-19-2010, 06:29 PM   #15
599 light looks the best IMO. I did H9 Hella bulb conversion and it awesome compared to standard 599 H11s, I'm not even talking about 919 original unit
Old 08-19-2010, 07:06 PM   #16
Tries Too Hard....
mntnceguy's Avatar
Got a link or # for the Lynx Headlight setup? Google isn't helping.....and I need a windshield
ALL PARTS HAVE ARRIVED....let the wrenching begin!!!
My 9'er had a low side slide.....She's down but not out......and about to rise from the ashes!
Currently:
2004 Honda 919 Silver
599 Headlight
Buell M2 shield
Givi Crash bars
Dynojet PCIII
Akrapovic exhaust - GSXR shorty CF
Seat with gel insert and re-shape
Custom LED Rear lights w/ vizi-tech flasher
Competition Works Fender Eliminator
Front 3-way LED Turn Signals flushmount
6-Spoke wheel conversion ( 900rr / F3 )
Michelin Pilot Road 3 - New @ 19940 8/10/11
Dyna Beads for tire balancing
17t / 44t Sprockets
Piaa horns 400 & 500 hertz
Ohlins rear shock from an F3, Re-Valved/Sprung
F4i Forks, custom sprung/sealed
ASV levers - Black W/Red Adj.
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Custom one-off Bars W/Heat
RC51 front brakes w/Bremzen pads-10 button rotors
Buell Ulysses Foot Peg conversion
etc, etc,
mntnceguy is offline   Reply With Quote
Old 08-20-2010, 12:51 AM   #17
That's damn funny!
The Shadow is online now   Reply With Quote
Old 08-28-2010, 05:25 PM   #18
Tries Too Hard....
mntnceguy's Avatar
Ummmmm......hello? Thanks for the hook-up??....Guess I was asking to much eh....sorry
Currently:
599 Headlight
Buell M2 shield
Givi Crash bars
Dynojet PCIII
17t / 44t Sprockets
etc, etc,
Old 08-28-2010, 05:43 PM   #19
Don't take it personal. He hasn't been on here in a while
Last Activity: 07-26-2010 04:09 AM
Old 08-28-2010, 09:51 PM   #20
schrock86's Avatar
Do you just like the look of the 599 light better or does it also function better?
schrock86 is offline   Reply With Quote
Old 08-28-2010, 10:18 PM   #21
functions way better than stock.... actually has 2 separate bulbs, with two "separate" reflectors for those bulbs... produces a much better beam. than the stock 919 headlight.
I do have a question about the stocker headlight.... would there be issues if i say ran both the high and low beam when i switched to high beam?.... id of course run a relay, but would the draw be too much for the magneto to output... or would the bulb housing get too hot?
Old 08-29-2010, 05:25 PM   #22
Tries Too Hard....
mntnceguy's Avatar
LOL, I know....I'm just
Currently:
599 Headlight
Buell M2 shield
Givi Crash bars
Dynojet PCIII
17t / 44t Sprockets
etc, etc,
Old 08-29-2010, 06:30 PM   #23
nd4... i run my 599 headlight on highbeam every day during daylight hours. havent had any issues as of yet so i think you will be fine.
LOVE the 599 conversion!
Pvster is online now   Reply With Quote
Old 08-30-2010, 01:30 AM   #24
schrock86's Avatar
Did you get your 599 headlights on eBay or is there another source
Old 08-30-2010, 03:20 AM   #25
brand new, they are going for around $180 including bulbs
Old 08-30-2010, 11:22 AM   #26
check out the 599 conversion thread.
Old 08-30-2010, 04:09 PM   #27
Zaq, I'm goin' to re read the 599 thread and look into this further, but, is the difference in beam really that drastic of a difference?(please be honest) I really need something more on the 919 for night riding.
Old 08-31-2010, 06:44 AM   #28
yes, especially since I upgraded to H9 bulbs
Do yourself a favor: while getting parts, get H9 connectors instead of H11s and get a set of H9 bulbs.
these is what I have in mine:
Amazon.com: Hella H83357011 H9 12V/65W High Performance Xenon Blue Halogen Bulb: Automotive
I'll try to snap a few pics of the beam if I remember
Old 09-02-2010, 05:06 PM   #29
as promised. FYI, I didn't use that device which makes H beam come up with L beam as in 599 headlight thread. My H beam and L beam work just like on stock 599. It's plenty bright for me as is.
low beam pics
High beam pics
Old 09-02-2010, 05:48 PM   #30
That looks pretty impressive, I'd like to see it sometime, shoot me a PM if you think we could meet(since we're in the same state...), I'll buy the, um, soda...
Old 09-02-2010, 06:29 PM   #31
i paid full retail for my 599 conversion and dont regret it 1 bit. i also have it set up so both bulbs fire on high beam. i do alot of riding early morning and late at night, in rain, etc and these lights are awesome with just the standard h11 bulbs. i cant even think of what the h9 bulbs would be like...
the 919 headlight used to get washed out by the street lamps as i rode by, NOT anymore!
Old 09-03-2010, 04:34 PM   #32
I think I'm sold, sounds like a good winter(or sooner) project.
Old 11-17-2010, 06:16 PM   #33
mobotix's Avatar
Does anybody know if the 4" dual headlights sold on ebay will bolt up to the stock brackets? (Just type in "919 + dual + headlight). Or is there a known list of dual headlights that will work on our bikes? I think a dual conversion will be my winter project.
Danmoto carbon pipes, dual headlights, flapper mod, frame sliders, K&N, tail tidy, smoke turns, cafe mirrors, windshield, 1" bar riser, PAIRS plates.
mobotix is offline   Reply With Quote
Old 12-01-2010, 05:50 PM   #34
corndog67's Avatar
According to last months Cycle World, you can get dual Buell something or another model headlights, buckets and bulbs for $116. Sounds pretty cheap to me.
corndog67 is offline   Reply With Quote
Old 12-01-2010, 06:04 PM   #35
Huh...there's a thought. Thanks for the info Corndog!
Old 12-01-2010, 06:40 PM   #36
corndog67's Avatar
Check the issue with the Super Tenere on the cover. It's on Roland Sands Sportster.
No, wait, it's on John Burns R-1.
