Join WristTwisters Today
Old 03-03-2010, 01:24 PM   #1
deadeye211's Avatar
fumoto drain valve
does anybody know what the thread size is for a 919 oil drain plug, i was thinking of putting in a Fumoto drain valve.
07 Bandit 1250 - hers
deadeye211 is offline   Reply With Quote
Old 03-03-2010, 01:55 PM   #2
According to Ron Ayers site it's 12mm. It's #14 in the attached.
Ronayers.com Fiche Desktop Motorcycle Honda 2002 CB900F OIL PAN OIL PUMP
Anything is possible if you don't know what you're talking about.
Old 03-03-2010, 02:09 PM   #3
deadeye211's Avatar
how about pitch, M12 x 1.25, M12 x 1.5 or M12 x 1.75????
Old 03-03-2010, 02:47 PM   #4
deadeye211's Avatar
i googled the part# and it's a M12 x 1.5. Fumoto part # F109. i am going to order one of these.
i will update when it's on, but not until next oil change.
Old 03-03-2010, 02:59 PM   #5
I like the idea, but since it sticks out it would be all too easy to catch it on something in a crash scenario ripping it out of the hole, spilling oil everywhere, probably irreparably damaging the threads or possibly even knocking a chunk out of your casting too.
Plus in my case it would never be allowed to pass tech at the race track...
Old 03-03-2010, 03:58 PM   #6
If the drain plug was hidden by a bunch of stuff you'd have to remove to get to it then a drain valve might make sense, but as the 919's drain is hanging out in front of god and everybody it isn't really needed. Wanted maybe, but not needed.
Also, while I haven't seen one on a bike I have seen them on cars, most notably a Honda that needed a motor replacement due to oil starvation from very well aimed rock that opened the valve and dumped the oil until the "time to replace the motor" light came on. An insurance claim and annoying. Dropping 4 quarts of oil right in front of the rear tire, however, open a whole 'nother can of worms.
The choice is yours.
robtharalson is online now   Reply With Quote
Old 03-03-2010, 04:30 PM   #7
DualSport Transplant
On a sort of related note, is there a magnetic drain plug available for the 919?
ALS919 is offline   Reply With Quote
Old 03-03-2010, 05:14 PM   #8
I've ran one of the Fram drain valve setups on two pickups I've had. I like them because there's no valve. It's a cap you remove and then a hose that has a stem that depresses the valve stem of the "plug". They work great on those.
Like Rob siad, the 919 plug is so easy to get to it's not a real problem when servicing.
