Are there any aftermarket shifter pedal options for a 919? - Wrist Twisters
 1Likes
  • 1 Post By robtharalson
post #1 of 5 Old 04-17-2017, 06:12 PM Thread Starter
The Dead Head
CB 919's Avatar
Question Are there any aftermarket shifter pedal options for a 919?
I've been searching like crazy, but I'm not finding any options for an aftermarket shifter lever (AKA pedal). I'm looking for something a little longer than the OEM, and maybe sticks out a bit further. I've seen some by SW Motech, but can't find any to fit the 919. Anyone found anything aside from the OEM? I'm not looking for rear sets
Common Sense...so rare, it's kind of like a SUPER POWER!
CB 919 is offline
post #2 of 5 Old 04-18-2017, 07:18 AM
If you have a good idea of how long you want it to be all you need to do is take it to a welding shop and they can cut it and add enough material to put the pedal right where you want it. It's mild steel which is easily worked / welded. It should cost less than $30 - 40, and take less than an hour depending on how busy they are.
CB 919 likes this.
post #3 of 5 Old 04-18-2017, 03:04 PM Thread Starter
The Dead Head
CB 919's Avatar
Thanks Rob, I'd thought about that, but I was hoping there might be an aftermarket adjustable someone might know about. If I can't find anything, I'll probably go that route. With all the other aftermarket parts & accessories for this bike, I thought I'd have a huge choice for a shifter.....apparently not.
CB 919 is offline
post #4 of 5 Old 05-18-2017, 03:38 PM
Look at this on eBay http://www.ebay.com/itm/141581266378
Gday CB919. Found this adjustable shift lever when I was looking at cycle pirates footpegs, which someone had put on their bike in another post. No idea if the shift lever would fit the 919 though.
post #5 of 5 Old 05-18-2017, 04:48 PM
theres yer ticket right there. good find islandboy
Originally Posted by Islandboy View Post
Look at this on eBay Cycle Pirates Adjustable Shift Lever Chrome ASSH-S*
VintageHunter
"always looking for that next find".
VintageHunter is offline
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
