Old 01-06-2010, 06:22 AM   #1
MachMoto.com
Ripper's Avatar
$5.00 Fender Eliminator?
As some of you know, I am putting the bike back to stock so I can sell it. Well I had the plate mounted in the under tail section of the bike and with the stock exhaust it is NOT a good place. It was totally invisible, except from directly behind. Here is a simple break down of what I did to fix this.
Here is the before shot
and Now!
What did I do you ask? Well it really is quite simple, I didn't take any before pics but I think I can walk you through it.
Lowes or Home Depot, Pick up a couple bolts and lock nuts as well as a piece of aluminum angle (comes in 3 foot sections and is in the same isle as the nuts and bolts) I spent under 5 bucks for the aluminum angle and the hardware, your experience and totals may be different.
1. Remove the rear Cowl and then the Fender
2. Remove the Plate Light and turn Signals from the fender before trimming.
3. Trim the rear fender to Match the lines of the bikes rear section. You should end up with just the very top section of the fender to reinstall.
4. Mark your holes in the rear section of the fender for the Plate light installation. It should just barely fit between the two cross supports in the trimmed fender and you want the top of both to be flush.
5. Install the Plate light on the trimmed section of fender.
6. Reinstall the trimmed section of fender on bike using only the two front screws, you will be replacing the rear screws with new Bolts and Lock nuts so you can remove the Threaded Retaining Clips in the rear section.
7. Install the Plate Bracket from the bottom, secure it and the rear section of the trimmed fender with New Bolts/Lock Nuts.
8. Reinstall the cowl and your done (if you have an integrated Brake light that is!) I do, so I didn't have to screw with the signals. If you don't... well your on your own because I didn't get that far.
Here are some pics after and during the install. If I get bored in the next few days I may take it all apart and do a complete walk through... Don't count on it though!
Here inside this spoiler, are some photos from different angles.
Ripper is offline   Reply With Quote
Old 01-06-2010, 07:18 AM   #2
Nice writeup - Thanks for taking the time to document it.
Mike's Bikes
Old 01-06-2010, 07:53 AM   #3
Nicely done Steve!
Old 01-06-2010, 08:35 AM   #4
MachMoto.com
Ripper's Avatar
Heck, I didn't document it. I think I'll disassemble it again for better step by step directions. It really was easy though, far easier than the undertail installation I previously had. I got to say though, it's kind of weird having a bike that quiet.
Thanks though! It does look "Factory"!
Old 01-06-2010, 08:37 AM   #5
Night Stalkers Don't Quit
RoboStraub 919's Avatar
Interesting little write up, I've been looking for little projects to do to the bike while it sits in storage.
Sell it? So uh, I seem to remember how ballsy your exhaust sounded when you were here for the MotoGP. Have any plans for that? lol
MH60M - The only Chopper for me...
RoboStraub 919 is offline   Reply With Quote
Old 01-06-2010, 08:56 AM   #6
Ballaholic
hornet919's Avatar
sellin anything interesting off your bike??
hornet919 is offline   Reply With Quote
Old 01-06-2010, 09:00 AM   #7
MachMoto.com
Ripper's Avatar
Office/Shop/Garage
You are the third person to ask what I'm doing with the exhaust since it sold about 3 weeks ago.
In storage? I keep my bike close at all times... Like in my office which is where I did 95% of this, plus I removed the 900rr system and reinstalled the factory system all right next to my desk. I did have to move it into the garage and use the Forklift to suspend the bike while I put that blasted Y-pipe back on though. Even with a Forklift, that thing is a PITA!!!
Old 01-06-2010, 09:01 AM   #8
MachMoto.com
Ripper's Avatar
I may be selling the CRG Mirrors? Not sure yet. That's about it though, it really is just about back to stock now.
Old 01-06-2010, 10:00 AM   #9
if you do, i call dibs on ur mirrors just let me know and i'll get the money to ya
Old 01-06-2010, 10:29 AM   #10
MachMoto.com
Ripper's Avatar
Deal... you can send the Ten Meeelllion dollars to my paypal!!! LOL...
Old 01-07-2010, 04:27 PM   #11
MachMoto.com
Ripper's Avatar
Mods... Please replace the frist post with this.
Okay, I did find some time to do a walk through of the $5.00 Fender Eliminator. So I deleted the old post and put up this nice clean one!
Old 02-09-2010, 06:17 PM   #12
Nice write-up.
It's a shame that my number plate in New Zealand is too wide to fit between the mufflers. I do however, have a plan, and a nicely bent piece of alloy ........... just need to find the time!
