Go Back   Wrist Twisters > Motorcycles > Streetbikes
Old 02-07-2012, 09:52 AM   #1
Honda 919 Powercommander maps
hey all
just built me a new exhaust put the m2 vale single side twobros can on the bike. was looking to see if any one has a map for a single side exhaust of any sort for the honda 919. i am gonna make a new intake inlet before i have a map built
thundertusk is offline   Reply With Quote
Old 02-07-2012, 11:19 AM   #2
Originally Posted by thundertusk View Post
hey all
A "new intake inlet" ?
You mean something to most likely nicely screw up the inlet ?
Old 02-07-2012, 11:53 AM   #3
mcromo is right here though. it'll take a lot of tinkering with a honda intake design to make it work as well as oem (if better is possible at all). one thing honda engineers know is their intake designs!!! i've dealt with tinkering enough honda intakes to conclude they know their shit in that area and sometimes oem is just best left alone performance wise. however, cosmetically it's an entirely different story! they sure like fugly intakes
Pvster is online now   Reply With Quote
Old 02-07-2012, 12:58 PM   #4
I paid to have a series of dyno runs done to compare stock to BMC filter plus side cover on /off comparative runs.
The BMC nets a hair, the only justification for having one is it being a life long filter, and only if you plan to be a life long owner.
The side cover on /off barely showed anything, and once I looked at it closely, I realized that simple run to run variances of coolant and oil temps would explain it all. I defy anyone to come up with a revised inlet that still has a stock or stock dimensioned filter in place, that yields the same, let alone any more torque or power, anywhere on the curve.
Case closed.
Old 02-07-2012, 02:32 PM   #5
pretty much well known there designed to run on still air....any sort of ram air intake track could result in more on the very top end and could only be measured at the drag strip and will effect low mid power on the down side
secondchance is online now   Reply With Quote
Old 02-07-2012, 03:00 PM   #6
IF a properly designed, located and practical arrangement can be fabbed up, or course it would help.
Old 02-08-2012, 12:34 AM   #7
Reason to try new intake inlet came to me looking at measurments is inlet on filter is 70mm inlet opening going to filter is only 60mm. Beside everyone nit picking my thoughts on intake, back to other part of post. Has anyone got a map for single side exhaust.
Old 02-08-2012, 05:51 AM   #8
Rockin' the 919
MF1VE's Avatar
Yes, g00gl3it does. There are at least two maps in the Dropbox folder. PM g00gl3it to gain access.
MF1VE is offline   Reply With Quote
Old 02-08-2012, 06:44 AM   #9
M112-004 map is a standard PC issued map for a Two Bros 4:1
The Simpson map is a variation of that.
I think both are sea level derived maps.
g00gl3it has a good map derived at 5,000 ft or so.
All the above mentioned maps are in the Drop Box
g00gl3it is again thanked for setting up the Drop Box.
Old 02-08-2012, 03:34 PM   #10
like the vmax intake track gets longer the higher the rpm or faster you go.... then again its a 20.000 dollar machine set up at the factory...not a pop on part
remember watching dyno runs for several years....tuner would make dyno runs with filter off 8 to 10 runs make adjustments along the way...add the filter and only lose 1/2 to 1 hp.......besides we have the flapper valve
Old 02-09-2012, 12:12 AM   #11
What's the deal with flapper valve does anyone run it or does that get pulled Fairly early
Old 02-09-2012, 06:38 AM   #12
It's there for intake noise reduction.
Old 02-09-2012, 03:48 PM   #13
Commuderator Munity
I explain it a bit here:
While you're at it, do the pair removal .
Send me a PM with your email address and I can send you some maps to try, or if you want access to the Dropbox folder that we share (if you know what it is), I can do that as well.
2006 Honda VTX 1300C (traded)
g00gl3it is online now   Reply With Quote
Old 02-10-2012, 11:12 AM   #14
Rockin' the 919
MF1VE's Avatar
Slight tangent - I installed the used serial port PCIII last night, and I ported the Pvster map to the .map format (I am at about 4000 feet ASL). REALLY enjoyed my ride into work this morning - the engine was SO smooth, and user-friendly - I was impressed with the difference.
If you want, I'll add a few notes to the map, and save in the Dropbox.
Old 02-10-2012, 12:23 PM   #15
Commuderator Munity
Please do!
Old 02-10-2012, 01:17 PM   #16
hahah, if you liked that map..... you should try my new one i just got last weekend. dude was having issues with the 919 dumping fuel after the fan kicked on and while it's an overall decently nice tune, issues reared their ugly head in stop/go traffic when cold out and the fan kicked on. this new map had at least 18% of fuel taken out across the bottom half of the rpm range and the result removed most (if not all, still need to do more testing) of those issues and made significant improvements on my cold start issue. i'll continue playing with it and have mcromo go over it with me before i post it up.
Old 02-10-2012, 03:29 PM   #17
Commuderator Munity
Pvster, throw your map in Dropbox, if you have access...
Old 02-10-2012, 03:41 PM   #18
more things change the more they stay the same...years back people would change there jets all the time looking for that perfect combo...now they play with there maps,,everyone thinking theres is the best.....in the end it dont matter if running worse or better,,it only matters what you think or think you think
Old 02-10-2012, 09:38 PM   #19
Rockin' the 919
MF1VE's Avatar
Sounds good, I'll post up the converted old map, and try out the new one when you've got it uploaded.
Tags
919, honda, powercommander
