I got annoyed by tailgaters and found the wonderful enhancement of running lights, and extra modulated brake lights!
I installed the combo of Electrical Connection's turn-signal=>running & brake conversion and Kisan's brake light modulator. The pix show parts and results during braking! Install took 3hr. Let me know if you want more info.
Now if I could just flash sync the LEDs to my subwoofer!
A little paranoid about a rear-end incident are we?
Not so much rear ending, but must create rear space to allow evasive options. Most moto accidents the rider is fine after the first bounce, it is the tail gating car that does damage. Call it experience.
If it works, go for it! I've been tailgated a few times recently. It's uncomfortable and can be slightly distracting to have to watch the cage behind you as well as what's ahead. Nice to have plenty of throttle available though, just zip away!
For years, there have been circuits called color organs which can be configured to vary the intensity of a light, or bank of lights, in response to sound input. With the use of a device called a VCO (Voltage Controlled Oscillator) you could vary the flash rate to correspond to input from your subwoofer. What music would you play to prevent tailgating?
I want more information on these.
Those VCOs would be great for home parties!
DISCLAIMER: Do not attempt a wiring install unless you have circuit experience. Doing this install incorrectly could easily short your bike's electrical system while riding and cause your Death! If unsure of your skill level please hire an expert Installer.
Attached are the requested info project pix (please pardon the focus of my lousy camera). #22 shows using steel wire to fish the lines through the turn signal brackets. I didn't use use the sealed housing, since then they wouldn't be sealed. Home wire pull lube was used on the signal's seal plug. #39 shows the wire electrical tape wrapped to the turn signal wire. A VOM determined polarity...we don't need stinking manuals! My 9r's solid green wire was consistently ground. I soldered (didn't use the flaky contact hardware) the wires and modulator close to the SOURCE plug, not to restrict the tail piece's removal line slack. I only cut one wire, the brake wire to circuit insert the modulator. The other contacts I didn't cut, ONLY carefully stripped back 1/4" of insulation #31. I flux soldered with difficult to work with higher silver content rosin core solder that is durable #33, #35. #38 shows the all the lines weather taped, heat shrink tubed and packed up. #36 shows the running light (lower output than during braking). The modulation rate decay works great!
I just returned from a night 70ml ride sharing the road with the shamrock celebrators. We had several potential tailgaters come up behind us on the freeway. I just gave the brakes a brief touch and wallah they immediately changed lanes and went around us. The communication works!
I've been rear-ended (last fall) and I looked at this and said.. woohoo thats on a 919.. I could do that on my... oh wait.. my rear turn signals have been removed in favor of an intergrated (into brake light) set... partially so I could mount my givi hard bags... but this is very cool..
Glad you like it! Thank goodness you are ok and still riding! The integrated lights are fancy, but may be confusing to a tailgater. I prefer simplistic functionality that maximizes safety. You could make some brackets to mount the OEM turn ears behind the hard packs.
So I wasn't excited about the stock turn signal yellow lenses displaying the running and brake lights orange (instead of red). I found clear alternatives makes clear lenses for 9r and smoked bulbs!
I installed the clear lenses. The chrome bulbs were worthless since they are LESS than half the brightness of the packaged bulb. Brakes are now red (not orange). It looks much cleaner than the stock yellow lenses. Before you toss your "lean indicators" for something less visible/safe, check these out.
While riding through frisco today I glanced at this 35' wide ad board for the new pirates of the caribbean. Then traffic stopped, but I had plenty of room for a quick stop. Then I thought... what about the woman behind me eating her lunch. Fortunately she saw my AC-TL and gave me plenty of room!
Any suggestions on godd vs. bad brands re: tailight oscillators?
kisantech's TL modulator is the best. Their modulator is microprocessor controlled (not a simple constant rate RLC circuit like the rest) to create an exponential decay flash (initially a fast flash then it slows) while touching the brakes. When a speeding car is coming up from behind you are very vulnerable and the AC-TL commands attention.
Can't say I've seen a modulator in action, either. How does the "reset" work?
I tend to brake early, brake often.
The modulator automagically resets instantaneously when you release the brake light. So there is technique not to let it reset by continually lightly touching either lever, then after ~4s it remains lit (while touching the lever). The cycle option is loosely under your control.
Any chance you still have the pics? I'm looking at the same kit from Electrical Connections along with an LED board from Clear Alternatives (if they have one with white LED's so I can keep the OEM lense) and the modulator from Kissan. Do you have the modulator working with the EC kit? Any advice would be greatly appreciated.
