Go Back   Wrist Twisters > Wrist Twisters > Motorcycle Discussion
Old 01-30-2012, 04:44 PM   #601
Needs training wheels.
Brewcrew02's Avatar
Got my new to me slightly blemished tank today! Removed and stripped the OG really dented one and readied for paint. Mended the cracks in the tail piece for bondo-ing. Pics soon. On a side note, when pulling the tank, I just pulled the fuel pump out and left it attached sitting on the frame. Will it be ok there for some time or does it need to be covered/removed/anything?
Brewcrew02 is offline   Reply With Quote
Old 01-30-2012, 06:57 PM   #602
Commuderator Munity
We threw Osiris' in a double plastic bag and then a bucket. I would at least cover it to keep it clean...
Android rules!
2006 Honda VTX 1300C (traded)
g00gl3it is online now   Reply With Quote
Old 01-30-2012, 08:54 PM   #603
Rockin' the 919
MF1VE's Avatar
Got the OEM windscreen today, and installed it when I got home. 30 degree F test ride tomorrow morning on the way to work! Living in the mountains and driving 38 miles out to the desert to work gives me a big swing in temperature - sometimes up to 70 degrees from early morning to mid-afternoon.
MF1VE is offline   Reply With Quote
Old 02-01-2012, 05:45 PM   #604
Signifer
installed the pair removal plates.
and I ordered these
much better looking than the standard ram mount base
boogunoogun is offline   Reply With Quote
Old 02-02-2012, 08:09 PM   #605
Brewcrew02's Avatar
Hey look at this!!
http://i200.photobucket.com/albums/a...-29-27_393.jpg
http://i200.photobucket.com/albums/a...1-29-38_15.jpg
Old 02-02-2012, 09:07 PM   #606
Commuderator Munity
More to come, I've been busy ;-)
Old 02-02-2012, 09:37 PM   #607
uh? readable english please? i'm very offended....
Old 02-02-2012, 09:47 PM   #608
Commuderator Munity
You show me how to enable subs in a video and make it available on youtube and I'll do it.
Basically, I had sideways throttle play in my grip. It bugged me, so I made a plastic shim that went on the outside near the bar end; enough to keep it snug but not bind the throttle.
5/8ths socket used to cut internal diameter, and 24mm to cut the outer. Used a plastic cap off of the round cardboard tube (that my carbon fiber vinyl came in).
Speaking of:
Old 02-02-2012, 09:52 PM   #609
Commuderator Munity
Full Gallery Ohlins Shock install
Teaser:
Old 02-02-2012, 10:00 PM   #610
Commuderator Munity
Something I should have done when I put my 900rr header on. Probably didn't need it at the midpipe. The fit was already so dang tight from the ceramic coating, but at the midpipe to can junction it definitely needed it.
Old 02-02-2012, 10:03 PM   #611
Commuderator Munity
My GSXR master cylinder didn't have a mirror mount like the stock one does, so I had to buy one on Amazon (~$10).
had to shift some things around a bit, bend my reservoir mount forward a bit (took advantage to also paint it black) and re-adjust my lever, but I finally got my left mirror back on
Old 02-02-2012, 10:10 PM   #612
Commuderator Munity
They are not as pink in person as they are in the photo.
If they start to fade in the sun, I'll replace them with black.
Old 02-02-2012, 10:33 PM   #613
looks good! keep up the work! oh and if u ever want to sell the mirrors, i'll be your first buyer hahah.
as for subtitles, you'll have to edit them into the video yourself. the english transcribe thing is crap lol! comes up with some hilarious choice of words though!
Old 02-03-2012, 01:31 PM   #614
Signifer
where did you put the straps on the bike from the ladder? I'll be installing mine next week. just the 2 square bars underneath the seat? Did you have to lift the front up on a stand before you raised the rear with your ladder technique?
Old 02-03-2012, 04:14 PM   #615
Stated reassembly on the back half of the bike. Also spent an hour or so organizing the shop, only to blow it apart in 5min.
'02 CB919
"The large print giveth, and the small print taketh away"
Tom Waits
HeliMech is online now   Reply With Quote
Old 02-03-2012, 04:58 PM   #616
Toast's Avatar
Whoaaa I like your seat collection there haha.
I gave my bike a quick spray wax today. Ohhh yeahhhhh 8-)
06 F4i
Toast is offline   Reply With Quote
Old 02-03-2012, 05:36 PM   #617
Warped man...
Cheeseburger's Avatar
Last batch of new parts came in today. Front and rear rotors, Pilot Road 2 front tire, DID chain, rear brake pads. Just gotta find time to put it all on...
Does this napkin smell like chloroform? Just kidding baby lemme buy you a drink.
Cheeseburger is offline   Reply With Quote
Old 02-04-2012, 08:59 PM   #618
Signifer
Just put together a better ram ball mount. Handlebar mirror bracket + 1" RAM ball with 10mm thread. It just looks better than the U bolt and rubber bolt ends.
Old 02-04-2012, 10:20 PM   #619
Rockin' the 919
MF1VE's Avatar
Made my own OEM style windscreen in CF:
and also changed the fork oil.
Old 02-04-2012, 10:21 PM   #620
Commuderator Munity
Originally Posted by MF1VE View Post
Made my own OEM style windscreen in CF...
Carbon fiber fork oil? I hear it's lighter.
What kind of oil do you use in your engine...?
Old 02-04-2012, 10:30 PM   #621
Rockin' the 919
MF1VE's Avatar
Maybe I should use the oil we use at work for the cryogenic pumps - Krytox GPL-103 (perfluorinated oil). Only $2800.00 per gallon.
Nah.
Old 02-04-2012, 10:33 PM   #622
Commuderator Munity
Nah.
Way too expensive. I found it here for MUCH cheaper:
20 kg / 5 Gallon Pail KRYTOX[REG] GPL 103 Clear General Purpose Line Oil | Fastenal
Only $2412 / gallon.
Old 02-04-2012, 10:42 PM   #623
Rockin' the 919
MF1VE's Avatar
Hey, I'm going to bring that up at work. Buy now and save!!!
Old 02-05-2012, 07:53 AM   #624
SSATX919's Avatar
ill be installing a new chain, worked on it a little too late last night(got sleepy) and took too many links off the red one i had ordered, put on a new michelin pilot road 3 as well as new front and rear sprocket...and currently in the process of ordering an integrated tail light and led turn signals...anyone have tips for installing led parts? do i need a special relay or something?
SSATX919 is offline   Reply With Quote
Old 02-05-2012, 10:50 AM   #625
do yourself a favor, buy the CUSTOMLED unit, best unit out there for the 919! also while ur at it, buy the relay from the same guy that makes the CUSTOMLED unit and you're set!
Old 02-05-2012, 03:22 PM   #626
SSATX919's Avatar
got it! i got the relay from another link i saw on an older thread but its plug and play. cant wait for the stuff to get here
Old 02-08-2012, 03:41 PM   #627
Signifer
Started to install my ohlins. Had to stop to celebrate my mother's birthday.
Anyone ever install the remote preload adjuster somewhere other than the footpeg location?
Old 02-08-2012, 04:16 PM   #628
Commuderator Munity
Yeah, I've seen a few pics of it installed under the seat, to the side of the seat pan underneath. Etc.
Just do what works best that still leaves it accessible.
Old 02-08-2012, 05:57 PM   #629
Signifer
Well after going out to eat, I thought of this idea. It's too late in the night to do, so I shall do it tomorrow. I was thinking of only mounting the adjuster with 1 screw on the supplied bracket, and mounting the setup vertically attached to that little black electric thing. I took some pictures to give you a rough idea. I will need to grind a little out of the plastic tray where the old reservoir cable used to be. Should still be easily accessable yet hidden.
I'll post some pictures when I'm done
Old 02-08-2012, 06:16 PM   #630
Be careful, that's your lean angle sensor, don't break it...
Old 02-08-2012, 06:31 PM   #631
Signifer
Yeah. I wont drill a hole right through it.lol
Old 02-09-2012, 04:22 PM   #632
Signifer
installed my ohlins rear shock with a different preload adjuster location.
919 Rear Shock Upgrade
Old 02-11-2012, 09:55 PM   #633
Wrapped a bunch of parts in 3M di-noc carbon vinyl today. Very happy with the end results. Application was a little tricky and is a two person job, you really have to heat and tug on it to get it smooth.
'02 CB919
Tom Waits
Old 02-11-2012, 10:07 PM   #634
Rockin' the 919
MF1VE's Avatar
Wow, good job HeliMech. Di-NOC is great stuff.
As for me, I set the rear sag on the bike today with, my daughter wielding the tape measure. She's quite the little mechanic already.
I also spent WAY too many hours generating the CNC programs for my forthcoming rearsets. But at least the programs are written now.
Old 02-12-2012, 08:04 AM   #635
Thanks! A co-worker picked up a huge 200m roll for his tint/wrap business, I picked up 40 sq/ft yesterday to play around with. Me and a friend spent 8hrs in the garage wrapping anything that wasn't bolted down.
Like yourself I am hoping to get into doing some true CF layups this summer. It's been a long time since I laid any mats, going to tool up this summer and see if I still got it.
'02 CB919
Tom Waits
Old 02-12-2012, 02:38 PM   #636
ariannasdaddy's Avatar
^^if you do any CF stuff that you don't find to be perfect, let me know....lol
Arte et Marte
ariannasdaddy is online now   Reply With Quote
Old 02-12-2012, 05:02 PM   #637
Will do JT, you will be the first I call.
So I just finished wrapping my Buell M2 windscreen. Next up will be a set of OEM exhaust heatshields & a smoothed tail cowl. These will both be going up FS: once they are completed.
'02 CB919
Tom Waits
Old 02-12-2012, 05:06 PM   #638
Hey Ian, it's JP not JT or JC(another thread).. hahaha lol.!! Good times
Arte et Marte
Old 02-12-2012, 05:08 PM   #639
My bad.....lol.
'02 CB919
Tom Waits
Old 02-12-2012, 05:10 PM   #640
I was gonna order some of that stuff to go over my yoshi cans to cover the small dents and blemishes. Do you think it will hold up to the heat?
This is what I had my eye on
</title><meta name="description" content="16" x 60" Carbon Fiber Vinyl Sheet 40cm x 150cm BLACK in eBay Motors , Parts Accessories , Car Truck Parts , Decals, Emblems, Detailing , Decals Stickers , Graphics Decals |eBay"><meta name="keywords" content
Arte et Marte
