Go Back   Wrist Twisters > Wrist Twisters > Motorcycle Discussion
Old 01-17-2012, 11:53 PM   #1
Turn signals...
Ok, here's the deal. I had this rear turn signals with the fender eliminator but they had a leak and the water went through so I had to replace them. I found this ones on eBay and I just replaced them. The only thing is that they work fine and all but, I notice that the lights are blinking a little bit faster than before. Both, rear and fronts works great but they like I said, blink faster than before. I bough the ones specifically for my Honda 919 '06. 12v 20w. Is it normal?
Thanks guys!
bennylam17 is offline   Reply With Quote
Old 01-18-2012, 02:20 AM   #2
undercover919's Avatar
Did you happen to buy LED turn signals? If so then you are looking for a flasher relay that will slow the blink just search LED and flasher here and it should point you in the right direction.
2003 Honda 919
undercover919 is online now   Reply With Quote
Old 01-18-2012, 10:49 AM   #3
+1 to what undercover919 said, it sounds like you bought an led unit and so you'll need a flasher relay. customled makes a great flasher relay that is plug and play. while you're at it, i advise you to look into the customled integrated unit as i've no doubt in my mind you likely picked up one of the cheapo clear alternatives units and they are simply garbage. do yourself a favor and get rid of the unit you have now by moving your turn signals out of the intergated unit OR buy a high quality unit such as the customled.
do a search for some videos and you'll see the difference.
Old 01-18-2012, 05:21 PM   #4
Commuderator Munity
I responded to your question on the other thread, but again, here's the link:
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
2006 Honda VTX 1300C (traded)
g00gl3it is online now   Reply With Quote
Old 01-19-2012, 12:14 AM   #5
Thanks a bunch guys. Yes, I bought the led ones. I'm going to take care of that.
