Originally Posted by ariannasdaddy
I've tried clutchin up as well (in 2nd). Rear tire got loose (too cold I guess). I prefer not to try again. Lots of torque!
Bounce it! e.g. let off the throttle, before you crack'er open. I had that problem for many many many miles. Part of the problem was lack of tire in the back, once that was corrected it was just a matter of getting the front suspension compressed. It seems counter intuitive (you are trying to get the front end UP, not down) buuuuuuuuuuuuut, that's the way it rolls! I'm still far from comfortable pulling the front up, even more so now that I have been out of the saddle for ~3mo. Take it slow, take it easy, but you can get there. BTW, I run a 17t front sprocket, so it can be a little more difficult than it should be. I hear a 15t sprocket leads to hooliganism.
