A great product when used correctly. Orientation of the straps in concert with your tie-downs is critical. Not to be used with rubber mounted handlebars (ST1300).
I have two of them. I've used them numerous times. I've never had anything wrecked by them. Some fool, some where, some time probably managed to twist a grip with them. In which case, just glue on again, and be glad your plastics are in good shape because the bike didn't fall over.
Hagar, I've not had any problems. They're heavy duty.
When I was trailering and putting the bikes on back of the pick up a lot, I'd buy a new set of tie down straps every year, and write the date down on them. Cheap insurance. Ive seen lots of ebay ads over the years for damaged, used bikes that had fallen over, supposedly by torn or broken tie down.
If you don't have some sort of wheel chock, be sure and strap down the front tire. Just because the top of the bike can't go one way or another, doesn't necessarily mean the bottom won't go anywhere. The result is the same.
The problem with the Canyon Dancer is the cross straps rely on pressure to keep them from moving against each other. Which means you have to REALLY TUG down on the straps pretty much to excess to insure that the bikes suspension doesn't compress even further on a bump. If it does it can and will cause the Canyon Dancer harness to loosen briefly and the bike can lean to one side or the other if you are in the process of a lane change or roundabout etc.
I used Canyon Dancer harnesses for about 10 years of my life and well over 100,000 miles of trailering my motorcycles all over the country. In that time I had numerous problems with them and more than once opened a trailer door to find my bike laying on its side or against the trailer wall & yes I have had many handlebar grips moved out of place.
I switched to the CycleCynch harness in 2006 and I have not had one single problem with them.
I also now incorporate the Pit-Bull Trailer Restraints for my main rides and only have to use the CycleCynch for hauling friends bike or a spare if I deem in necessary.
There are few things worse than finding your bike laying on its side... Having said that, if my warnings fall on dead ears on this topic then they deserve exactly what they get.
I use Canyon Dance in conjunction with a wheel chock. Works very well. I do second LDH's comments that bumps tend to loosen the strap but so far its never been problematic.
I use a canyon dancer in the bed of my truck. strapped the canyon dancer forward to each front corner of the bed. Then I run two ratchet straps from the rear wheel forward to the same points in the front corners of the bed. No problems.
Digging up an old thread...
[MENTION=81]LDH[/MENTION], can you describe how the Canyon Dancer and CycleCynch differ? Looking at some pictures, they do about the same thing. Either way, I don't like tieing down the bike via the handlebars... just seems like a recipe for disaster.
I stumbled across something like this that you could just attach to the lower triples (if you have a naked bike) and it seems like the way to go (assuming something like this won't bugger up the forks). Welcome to Canyon Dancer, Inc. - Home of the original Bar-Harness.
The Cycle Cynch does not loop through itself. Because the Canyon Dancer does it relies on friction and excessive pressure on the straps to keep them from slipping against each other.
Related Threads
678.5K posts
10.2K members
Since 2006
