11-13-2008, 10:10 AM
#1
get use to the view...
v-twin roar
Some days you're the dog... some days you're the hydrant.
11-13-2008, 10:15 AM
#2
The "Eagle" Has Landed
Interesting... a little bit too much RC51, MV Agusta and Ducati 916 / 996 in there though. Maybe it's just me.
I wish them success.
11-13-2008, 10:18 AM
#3
...and you're riding what?!
11-13-2008, 10:27 AM
#4
Originally Posted by
h ryder
Dang! That was just plain mean brother!
Say hello to my little friend!
11-13-2008, 10:30 AM
#5
I've read about this bike...Pretty sweet, We'll see how they make out
2008 Yamaha FZ1-
Street
2005 Honda CBR 600rr-
Track
11-13-2008, 10:33 AM
#6
Pretty nice but why use a Harley motor?
11-13-2008, 10:34 AM
#7
dadogs
I was wondering that too... Was anyone able to find the price?
11-13-2008, 10:36 AM
#8
I haven't seen a price yet...I wonder how reliable it will be
2008 Yamaha FZ1-
Street
Track
#9
dadogs
It's the v-rod motor.. which was designed by porche.
11-13-2008, 10:37 AM
#10
h ryder
There ya go...That will explain the reliabilty thing
2008 Yamaha FZ1-
Street
Track
11-13-2008, 10:41 AM
#11
dadogs
To make it "all-american". Oh what ... where was that motor designed? Where's it made? Where are a majority of the parts sourced? Ah, forget it!
11-13-2008, 10:44 AM
#12
h ryder
Ahhhhh makes sense. I rode one of those for the first time a month or so ago and it pulls reasonably well for a Harley.
#13
WIM-RC51
If I remember correctly the price was low to mid $40k. Motorcyclist magazine did a test ride aboard one in this months issue. It amazed me how light they were able to keep the machine using the HD powerplant.
11-13-2008, 10:49 AM
#14
RC51_CBRXX
Dork
11-13-2008, 10:50 AM
#15
RC51_CBRXX
Maybe it just me... but I coulda sworn Porsche was a German company. That's just me though... just sayin is all.
11-13-2008, 10:52 AM
#16
wisco919
If I remember correctly the price was low to mid $40k. Motorcyclist magazine did a test ride aboard one in this months issue. It amazed me how light they able to keep the machine using the HD powerplant.
I too was wondering about the weight issue with that power-plant.
11-13-2008, 11:00 AM
#17
Here are the specs.
The Bike: The Roehr 1250sc boasts high-spec running gear – Ohlins suspension, Marchesini alloy wheels, Brembo brakes with radial-mount calipers at the front, composite bodywork and is powered by the 1250sc 180HP, specially developed supercharged version of the HarleyDavidson* 1250cc Revolution* engine. State of the art supercharger technology has been applied, providing reliable high power output with a broad, linear power delivery.
Engine:
2 Cylinder, Supercharged, Liquid Cooled, DOHC, Counterbalanced, 60deg, V-twin
Displacement:
1250cc
Bore x Stoke:
105mm x 72mm
Compression ratio:
11.3 / 1
Transmission:
5 speed
Clutch: Wet, multi-plate, hydraulic actuation, slipper type
HP/Torque:
180hp @ 9100 RPM,
115 lb/ft torque @ 7600 RPM
Final drive: 520 O-ring chain
The Chassis: A unique modular CrMo steel and aluminum frame has been developed. This frame uses these two materials at areas in which their material characteristics are best suited. The result is a stiff, light weight structure that provides unparalleled steering response
Chassis Type:
Steel/aluminum composite beam frame, 4130 steel/ 6061 aluminum
Wheelbase:
56 inches (1422mm)
Rake/trail:
23.5deg. / 89mm
Seat height:
31.5 inches
Dry weight:
432 lbs. (196kg)
Front suspension:
Ohlins 43mm fully adjustable upside-down fork with TiN
Rear suspension:
Ohlins fully adjustable linkless monoshock
Front Brakes:
2 x 330mm semi-floating discs, radially mounted Brembo 4 piston calipers.
Rear brake:
245mm single disc, with 2 piston Brembo caliper
Front Wheel/tire:
3.5 x 17 forged aluminum 10 spoke Marchesini, 120/70 ZR17
Rear wheel/tire:
6.0 x 17 forged aluminum 10 spoke Marchesini, 190/55 ZR17
Fuel tank capacity:
3.2 US gallons
Reserve fuel:
.5 US gallons
11-13-2008, 11:02 AM
#18
432lbs. dry???
11-13-2008, 11:11 AM
#19
h ryder
432lbs. dry???
That's just the engine's dry weight. They haven't finished all the frame specs yet....
11-13-2008, 11:12 AM
#20
Then put your fat a$$ on it...
11-13-2008, 11:16 AM
#21
NC Sasquatch
Ridge
11-13-2008, 11:18 AM
#22
Corner speed sets u free
wisco919
Dry weight:
432 lbs. (196kg)
She's fat for a sportbike, the new Gixer 1k only weights 380 dry. i do appreciate the 520 chain, Olins, Brembo brakes, & Marchesini rims etc.; however with only 3.5 gal fuel capcity you'll be fueling it up quite frequently.
and for 50k... i'll pass.
11-13-2008, 12:13 PM
#23
Motorcyclist claims a price tag of $50k and complained a bit of suspension problems that supposedly will be fixed in the production model.
Raises a question, though. Why the heck isn't Buell using the V-Rod engine? Seems like a perfect move for an engine that's largely ignored by the Harley audience.
11-13-2008, 12:19 PM
#24
h ryder
I'm not fat, I'm big boned.
Besides, you would just be that much more frustrated when I passed you on a H-D/Porsche w/ no frame.
Linear Mode
