Go Back   Wrist Twisters > Motorcycles > Twins
Old 05-10-2008, 08:08 PM   #1
RC Sato rear-set
Tricky being back with an RC question raised one I've had for quite sometime. It's something that I really never worried about, but should have.
For those that put on Sato rear-sets. How did you connect the rear brake light switch?
RC51_CBRXX is offline   Reply With Quote
Old 05-10-2008, 08:13 PM   #2
Go'n So slow I'm stopped
xrmikey's Avatar
What rear brake light switch?
Most use a hydraulically activated banjo bolt switch.
http://s2.pegasusautoracing.com/2008/078.pdf
xrmikey is offline   Reply With Quote
Old 05-10-2008, 09:18 PM   #3
No mo' 919
Trackday Recognition Veteran
+1
Rob recommended that I disconnect the rear brake
so I left a little air in the system to make it mushy
Sokali is offline   Reply With Quote
Old 05-11-2008, 04:35 AM   #4
On the Honda, they use a separate mechanical spring switch. I just realized that I never remounted it onto the new configuration and I'm certain that it fits?
Old 05-11-2008, 07:44 AM   #5
No mo' 919
For the 919, Sato supplies the pressure switch Mikey mentioned.
I cut off the spring switch and spliced in the pressure switch.
Mikey, did you have to cut off about an inch from the reservior to master cylinder hose?
Old 05-11-2008, 07:47 AM   #6
Never received it. It's been a few since my conversion. Looks like I'll have to buy one now.
Old 05-11-2008, 04:14 PM   #7
get use to the view...
h ryder's Avatar
hey Dave... was over in MASS riding today.
Some days you're the dog... some days you're the hydrant.
h ryder is offline   Reply With Quote
Old 05-11-2008, 06:51 PM   #8
Thanks for calling bietch! I'm in Mass ... leaving tomorrow. Actually thinking about just grabbing one of the bikes and heading west for a few days then back.
Old 05-12-2008, 03:06 AM   #9
h ryder's Avatar
like I knew you weren't @ WIM's trying to get some tail.
Old 05-12-2008, 06:52 AM   #10
I may be riding past your parts tonight. Depending on the time, I'll give you a call.
Old 05-12-2008, 07:21 AM   #11
The other Mikey will respond. I did not cut the hose.
Mike's Bikes
Old 05-12-2008, 09:05 AM   #12
NC Sasquatch
tarheelguy's Avatar
I never installed the switch that came with my Satos.
Your welcome to it (If I can find it)
I'll dig around this afternoon.
tarheelguy is offline   Reply With Quote
Old 05-12-2008, 09:06 AM   #13
You would be my hero! Thanks.
