Go Back   Wrist Twisters > Motorcycles > Twins
Old 12-08-2010, 05:20 AM   #1
Dead Wrong
Effe's Avatar
MT 01 - Simply Amazing
Here I found a great picture of a modified MT 01. I have always had a thing for this Yamaha but this is something else. Chasis and the front side including the brakes are from R1.
I couldn't find any detailed info about the engine power of this bike...
Effe is offline   Reply With Quote
Old 12-08-2010, 05:55 AM   #2
That's a wild machine.
Old 12-08-2010, 06:00 AM   #3
Hastatus Prior
Yamaha MT-01 - Wikipedia, the free encyclopedia
"Power 66.3 kW (88.9 hp) @ 4,750 rpm
Torque 150.3 N·m (110.9 lb·ft) @ 3,750 rpm"
Old 12-08-2010, 06:30 AM   #4
Gets censored
the chain is on the wrong side...
Old 12-08-2010, 06:57 AM   #5
Just guessing that that particular one puts a bit more power to the ground.....
Old 12-08-2010, 07:03 AM   #6
Stutz's Avatar
Over.co.jp makes some cool sh*t.
You should have seen some of the srx600's they put out.
MT01
Engin: Aircoold V-Twin OHV
Borex Stroke: 97.0X113mm
Capasity: 1670cc
Compretion: 10.5:1
EFI: Modifide ECU
Start: Moter
Max Power: 110ps/5500rpm
Max Toroqe: 16.0kgm/5000rpm
Gear Box: 5 Speed Standard
Resio: 2.375/1.579/1.160/0.935/0.800
Frame: OVER oval Aloy Frame
Swing Arme: OVER Aloy Original
Lengh: 2146mm
Wide: 580mm
Hight: 1130mm
Wheel base: 1517mm
Seat Hight: 846mm
Head angle/Trail: 24°/110mm
Tiresize: F:125/80R420-16.5 R:195/65R420-16.5
Dry Weight: 215kg
Fueltank capasity: 20liter
Stutz is offline   Reply With Quote
