Go Back   Wrist Twisters > Motorcycles > Twins
Old 10-20-2008, 02:30 PM   #1
Back in the day
Hondad's Avatar
05 RC51 fork assistance
The stop bolt on the right fork backed off and leaked fluid, when I reset my suspension back to the standard settings. I have disassembled the fork. Does any one have any experience with these forks? I have located some one with the damper rod tool so that I can torque the damper and the stop bolt together. I have the factory service manual and the parts that I removed are somewhat different in regards to the upper fork cap and spring spacer. Is there any special thing that I should be aware of reassembling the fork? Is the stop bolt coming loss a common thing? thanks
Hondad is offline   Reply With Quote
Old 10-21-2008, 02:27 AM   #2
get use to the view...
h ryder's Avatar
tarheelguy might be able to give some insight.
Some days you're the dog... some days you're the hydrant.
h ryder is offline   Reply With Quote
Old 10-23-2008, 05:55 AM   #3
Heavy Metal
ratdog's Avatar
http://www.rc51.org/
or http://www.speedzilla.com for answers on all things arrceee
ratdog is offline   Reply With Quote
Old 10-23-2008, 07:18 AM   #4
NC Sasquatch
tarheelguy's Avatar
Trackday Recognition Veteran
I've been in my forks 3 or 4 times.
I didn't need any "special tools" but all I did was pull them apart & change springs/fluid & add the 20mm spacer.
I guess what your refering to as the "stop bolt" is the allen head on the bottom of the fork (#10 I think). Mine never leaked. When I re-assembled the forks I just pulled up on the white plastic tube thing so that I could get a cresent wrench on those flat spots, and then torqued the bottom bolt with some locktite.
tarheelguy is offline   Reply With Quote
